FitBit
Latest about FitBit
Does using Fitbit software require a subscription?
By Courtney Lynch Last updated
Curious how Fitbit software works and what it offers? We've covered all the basics for you.
Fitbit Luxe vs. Fitbit Inspire 2: Which should you buy?
By Karen S Freeman Published
One is a bit fancier, while the other is less expensive and more battery-efficient. We're here to help you pick the right tracker for you.
Fitbit Versa 2 vs. Fitbit Inspire 2: Which should you buy?
By Nicolette Roux Published
When it comes to smartwatches and fitness trackers, Fitbit delivers. Should you buy the Fitbit Versa 2 or the Fitbit Inspire 2? Read on to find out.
Can you text on the Fitbit Versa 2?
By Jeramy Johnson Published
The answer to this question carries a big asterisk with it. Yes, you can reply to messages on the Fitbit Versa 2... if you have an Android phone, that is.
How to set up and use Fitbit for iPhone and iPad
By Luke Filipowicz Last updated
Trying to set up Fitbit on your iPhone or iPad? Here's how!
Fitbit Versa 1 vs. Fitbit Versa 2: What's the difference (and should you upgrade)?
By Nicolette Roux Last updated
The brand new Fitbit Versa 2 is launching September 15th. So, we're here to break down the differences between the Versa 1 and 2 for you, if you should upgrade, and why.
Garmin Vivosmart 4 vs. Fitbit Inspire 2: Which should you buy?
By Jodi Owan Last updated
The Garmin Vivosmart 4 and Fitbit Inspire 2 are incredible fitness wearables, but one outshines the other. Let's put them head-to-head and see which one comes out on top.
Should I upgrade to Fitbit Premium?
Fitbit Premium is a monthly membership through Fitbit that offers in-depth, personalized health and fitness guidance.
Fitbit Versa 3 vs. Sense: Which should you buy?
Do the Fitbit Versa's extra features make it the better choice over the more affordable Versa 3? We break down the pros and cons for the best fitness trackers Fitbit has to offer.
Pebble E-Paper watch gets a user interface demo but still no news on release
By chrisoldroyd Last updated
How to measure your wrist before buying a Fitbit
By Luke Filipowicz, Mick Symons Published
Every Fitbit purchase these days comes with a small and large band. Ensure your Fitbit will fit by measuring your wrist before you buy.
Best Fitbit for kids 2022
By Karen S Freeman, Daniel Bader Published
Fitness is important through every stage of life and your kids deserve to get in on the Fitbit action too! But, which Fitbit really is the best for your tyke or teen?
What color Fitbit Versa Lite should you buy in 2022?
The Fitbit Versa Lite, which is a great and affordable fitness smartwatch, comes in several color choices. Which one will suit you best?
Fitbit Charge 5 vs. Fitbit Charge 4: Which should you buy?
By Jodi Owan Published
The Fitbit Charge 5 has hit the streets. Is it worth it to jump from your older Fitbit to the new kid on the block? We're looking at the pros and cons and tossing in our opinion.
Fitbit Versa 3 vs. Fitbit Charge 4: Which should you buy?
By Jodi Owan, Mick Symons Last updated
Fitbit Charge 4 vs. Fitbit Charge 3: What's the difference and should you upgrade?
The Fitbit Charge 4 is on store shelves. Is it worth your money to make the jump from an older device or another brand of tracker? We're exploring the pros and cons and throwing out our two cents.
