The Lumsing dual articulating arm TV wall mount is down to $23.99 with code DSUMLN65 on Amazon. This wall mount normally sells around $40 and has never dropped much lower than that through direct price drops.
The dual articulating arm is a key component to this wall mount because it gives it a huge range of motion and allows you to move the TV to the best possible angle for you whether you're chilling on the couch or watching a game with a bunch of friends.
Features include:
- Fits most of 27-70-inch TVs up to 99lbs
- Fits VESA (mounting hole pattern): 75x75mm, 100x100mm, 100x200mm, 200x200mm, 300x200mm, 300x300mm, 400x200mm, 400x300mm, 400x400mm, 600x400mm
- Low Profile mount retracts to 4.3-inches to save space, extends 20-inches from the wall
- Tilt: 15 degrees down/forward
- Total Rotation: 60 degrees right/left
- Easy installation, installation manual and fitting screws and bolts included
- NOT suitable for 16-inch wood stud spacing. Fit below 12-inch wood stud spacing.
If you have a TV smaller than 27-inches or want a wall mount with a smaller footprint, you can get this AmazonBasics mount that is also on sale.
TL;DR
- What makes this deal worth considering? - This is one of the best prices we've ever seen. Beats any direct price drop on this item.
- Things to know before you buy! - Read the features and make sure this mount will work for what you're trying to do. Check your stud spacing, your VESA mounting holes, and TV weight before making this purchase.
More from Thrifter:
For more great deals be sure to check out our friends at Thrifter now!
New M2 13-inch MacBook Pro teardown shows it's just the old one in disguise
Apple's new M2 13-inch MacBook Pro is now on sale and people are doing what they tend to do with new things — they're taking the machine apart. The latest to take a screwdriver to Apple's new notebook is iFixit, and the result is further confirmation that this is essentially the M1 model but with some small tweaks and a new CPU.
Monster Hunter Rise: Sunbreak Collector's Edition has some awesome extras
The Monster Hunter Rise: Sunbreak Collector's Edition brings you a number of extra collectible items. They're of the highest quality and worth any fan's time.
Review: Logitech somehow made its best wireless mouse even better
The MX Master 3 is a fan-favorite among many for wireless mice, but Logitech just made it even better with the new MX Master 3S.
All the games coming to Nintendo Switch in July 2022!
If you're in the market for new Nintendo Switch games, here are the ones being released in July. Highlights include Xenoblade Chronicles 3, LIVE A LIVE, and Time on Frog Island.
