Best Monitor Arms (Single and Dual) iMore 2021
The stand that came with your monitor is probably serviceable. But I've never come across a monitor with a stand I'd truly call "great," even with most of the newer 4K monitors. At best, your monitor moves up and down when you want it to, and at worst, they take up too much space on your desk. That's why getting a mounting arm is a great idea for any workspace. It gets your monitor up off your desk and clears space, making more room for your computer, for instance, a new MacBook Air.
- Manage your cables: EleTab Single Monitor Desk Mount
- Beyond basics: AmazonBasics Premium Lift Engine Arm Mount
- Great budget option: VIVO Single Monitor Adjustable Desk Mount
- Heavy duty: 3M Desk Mount Monitor Arm
- Dual-wield monitors: VIVO Dual-Arm Monitor Stand
- Manage every cable in existance: EleTab Dual-Arm Monitor Desk Mount
- Nowhere near basic: AmazonBasics Premium Dual Monitor Stand
- Mount up: Jarvis Monitor Mounting Arm
- Adapt your stand: Husky Mounts VESA Adapter Plate
Staff FavoriteEleTab's VESA arm features a full 90-degree up and down tilt, full landscape, and portrait swivel, and channels for holding your monitor's cables to help keep your desk neat. It supports monitors up to 17.6 pounds.
This is a good stand at a reasonable price. The arm fully extends as you need it to, provides 15 degrees of tilt in every direction, and 360 degrees of swivel, making it easy to orient your monitor between landscape and portrait positions. It also supports displays up to 22 pounds.
This is a tough, heavy-duty monitor arm. Despite its strength, the arms are actually hollow, allowing you to run your cables through the arm to tidy up your workspace. It supports monitors up to 30 pounds, which should be enough to hold up an iMac.
If you've picked up two monitors and need to mount them both, this is a great option. It features a heavy-duty clamp, so the weight of two monitors won't cause it to tip over, and each arm is independent of the other so you can adjust each screen to the perfect height for your needs. Each arm supports monitors weighing up to 14.3 pounds.
Like its one-armed counterpart, this dual-arm desk mount from EleTab offers detachable cable management clamps that let you cleanly route your cables behind your monitor. Each arm supports monitors up to 17.6 pounds.
Utilizing a gas-activated mechanism, Jarvis' mounting arm will offer a sturdy platform for your monitor while still allowing for easy repositioning when it's called for. This option supports monitors with a weight up to 19.8 lbs and comes in black, silver, and white color options.
The arms on the rest of this list primarily support the 100-by-100mm VESA size, a common size for the mounting bracket on a lot of monitors. If you've got a monitor with a larger mounting bracket, up to 200-by-200mm, this plate from Husky Mounts will let you adapt any of the arms on this list to hold your monitor.
Our recommendations
These are all great monitor arms, but if I were getting one, I'd pick up the EleTab Single Monitor Desk Mount. It's a nice balance between price and ease-of-use, wide tilt angles, and built-in cable management as great additional perks make it one of the best monitor arms you can get for the price. But it'd be hard to go wrong with any of the monitor arms on this list. Each has the strength to hold most common monitors.
For anyone that needs to mount two monitors, EleTab also makes a Dual-Arm monitor desk mount, which lets you freely adjust both screens as you need to. Both arms can hold most flat-screen monitors under 18 lbs.
Get a Fitbit for your dad this Father's Day to keep him active
Father's Day is coming up, so get your dad a Fitbit that can track the metrics he wants. Whether it's weightlifting, cycling, running, or other forms of exercise, these are the best Fitbits for men.
Have a hearty meal ready when you get home with the best slow cooker
It's hard to eat well when we're all so busy with work and other commitments. There are tools that can help though, like a slow cooker that you can set up in the morning and leave to simmer during the day. There's nothing like a delicious meal waiting for you when you get home after a long day. Here are some of the best slow cookers!
No longer the joke: the best hoverboards on the market
Hoverboards may have been a bit of a joke a few years ago, but now they're a decent means of personal transportation. If you're in the market for one of these two-wheeled scooters, check out these options — they're the best you can buy.
