Source: Daniel Bader / iMore
Best Noise-Canceling Headphones iMore 2021
With the elimination of the headphone jack from many newer phones, wireless headphones are surging in popularity, and noise-canceling is one the most highly-requested features. If you're looking for the best noise-canceling headphones you've come to the right place Though once a premium feature found only in expensive headphones, these days, noise-canceling is available in the best true wireless earbuds not just over-the-ear cans like you might expect. The Sony WH-1000XM4 headphones are our top overall choice though because have class-leading noise-canceling properties and super-long battery life.
- Best Overall: Sony WH-1000XM4
- Best Luxury Option: AirPods Max
- Best Runner Up: Bose Noise Canceling Headphones 700
- Best Sound Quality: Bowers & Wilkins PX
- Best Battery Life: Jabra Elite 85h
- Best Budget Over-Ear Cans: COWIN E7
- Best Earbuds: Sony WF-1000XM3
- Best for Apple Lovers: AirPods Pro
- Best Neckbuds: Bose QC30
- Best Budget Neckbud: Phiaton BT 100 NC
Source: Sony
The WH-1000XM4 are the best noise canceling headphones for most people. If you need active noise cancelation (ANC), the WH-1000XM4 will undoubtedly come up in your conversation or Google search. In fact, the ANC is so good that really only the AirPods Max compete with it in our minds. On a flight? Commuting on a bus or train? Walking down the block? The WH-10000XM4 has your back.
In addition to stellar ANC, the WH-1000XM4 are really just a great headphone. The battery lasts up to 30 hours on a single charge with fast charging capabilities. Unfortunately, when charging, you won't be able to listen to the WH-1000XM4 either wired or wireless. When listening via Bluetooth, you'll get a best-in-class sound experience as well, with support for most of the major Bluetooth codecs, including SBC, AAC, aptX, aptX-HD, and Sony's own LDAC. The only major codec missing is aptX-LL, but most ANC headphones don't include aptX-LL anyway.
The sound signature out of the box is warm and dark. The bass, while smooth and even, is boosted quite a bit, giving it its warm sound signature. The lower mid-range is neutral and flat while the mid-mids, upper-mids, and the entire treble region is recessed, giving the WH-1000XM4 its dark sound signature. Fortunately, you can customize the sound with Sony's smartphone companion app. Unfortunately, you'll need to enter SBC mode to properly use the EQ as it gets disabled with higher quality Bluetooth codecs. SBC in terms of sound quality is fine, but the latency can be quite bad, especially when watching video or playing games.
Comfort-wise, the WH-1000XM4 is above-average. For most people, they'll be excellent. But, if you have a big head beware that they can get uncomfortable after a few hours of usage.
Pros:
- Long battery life
- Customizable sound
- Fast charging
- Amazing ANC
Cons:
- No simultaneous charging & listening
- Higher quality Bluetooth codecs disable EQ
- Can get uncomfortable for some with larger heads
Best Overall
Sony WH-1000XM4
Best for most people
The WH-1000XM4 is an overall great headphone with great sound, battery life, and comfort.
Source: Christine Romero-Chan / iMore
If you have a little extra money to spend, and you really want to get some of the best ANC you can get in a pair of cans today, the AirPods Max are perfect. They sound absolutely incredible, better than most of us at iMore thought they would, and the ANC is off the charts. Of course, the AirPods Max gives Apple users the advantage all the AriPods features you've come to love. It's easy to invoke Siri on command, pair the AirPods Max from one Apple device to the other, and features Transparency Mode, which allows you to hear the outside world.
As we mention in our AirPods Max review, it's pretty hard to find anything to like about the Smart Case the headphones come with. It does little to protect the headphones as a whole, especially the mesh canopy headband, which is its most vulnerable part. While the Smart Case does put the AirPods Max into an ultra-low-power mode to conserve battery, a few minutes without use will automatically make the AirPods Max start saving battery life anyway. You could, honestly, ditch the Smart Case and not miss out on much.
Unlike a lot of the best noise-canceling headphones, AirPods Max is made from quite a bit of metal and aluminum, which means they're dang durable. The headband is constructed from silicone and fabric mesh, which do feel comfortable on your head while you're wearing them. However, if you move your head around a lot, the AirPods Max weight becomes quite noticeable.
Pros:
- Amazing sound quality
- Class-leading ANC
- Premium materials
- Fast charging
- All the great Apple features
Cons:
- Smart Case is nearly useless
- Extremely expensive
- Heavy compared to other headphones
Best Luxury Option
AirPods Max
Amazing, if you can afford it.
if you can afford it, the AirPods Max are the best ANC headphones we've tried.
Source: Bose
It's taken them a few years, but Bose has finally updated its flagship ANC headphone line. Being the successor to its super popular QC35 IIs, the Bose NCH 700s are equal to or better in almost every way. First, let's talk about sound quality. The NCH 700s takes a small leap in this regard. The NCH 700s reduce the treble ever so slightly, so they're no longer piercing and sharp while maintaining a relatively flat and neutral sound signature.
Battery life is above-average, with up to 20 hours of usage on a single charge. Fortunately, when your battery is dead, you can simply plug in the USB-C charging cable and continue to listen to your NCH 700s, whether that's over Bluetooth or wired.
In terms of comfort, the NCH 700s are good. Some may argue the NCH 700s have the best comfort when it comes to an ANC headphone, and I'd have to agree. The clamping force isn't too strong, and the ear cups and headband are super soft. While comfort is excellent, the portability got notably worse with the NCH 700s over the QC35 IIs. The NCH 700s no longer fold, which is a big deal for a travel headphone. This means when not in use and stowed away, the headphone and included charging case will take up more space in your carry on.
But when you take them out and use them, the ANC from the NCH 700s are fantastic. They're not as good as the Sony WH-1000XM4 or AirPods Max, but they're easily the second-best ANC headphone on the market. They block out most bass-heavy engine noise, and some mid-range sounds such as people talking. It struggles ever so slightly on higher-pitched wines that come from smaller plane engines or electric cars. However, you do get up to 11 steps of ANC, giving you one of the most versatile ANC headphones on the market.
Pros:
- Battery life
- Sound quality
- Comfort
- ANC
Cons:
- Non-foldable design
Best Runner Up
Comfortable as heck
If you're looking for awesome comfort and sound, and good battery life, the Bose NCH 700s are right up your alley.
Source: Bowers & Wilkins
If you want slightly worse comfort and ANC but some of the best sound quality of any ANC headphone, look no further than the Bowers & Wilkins PX. The soundstage of the PX is one of the best we've ever heard on a closed-back headphone, let alone an ANC set. The sound quality is decent, with an overall V-shaped sound signature that many will enjoy. The bass is boosted, which will give you some thump and rumble, while the treble is also boosted but not enough to make it piercing or sharp.
But all this great sound quality comes at a sacrifice. The ANC is mediocre at best on the PX, and you basically should avoid enabling it at all costs because enabling it hurts the sound quality. However, passive isolation does pretty well. Comfort is only decent here, too: the clamping force is super strong, so you'll sometimes feel like its squeezing your head. Fortunately, the PX are super stylish, and if you're looking for some style points, the PX is one of the best-looking headphones around.
Battery life is great here, with up to 20 hours of usage. The headphone supports USB-C for charging, charging, and listening at the same time, and even being able to use the USB-C port for USB audio.
Pros:
- Sound quality
- USB-C for charging and listening
- Battery life
- Stylish
Cons:
- Comfort
- ANC
Best Sound Quality
Bowers & Wilkins PX
Stellar sound
Excellent sound quality with exceptional soundstage, but sacrifices comfort and ANC.
Best battery life: Jabra Elite 85h
Source: iMore
Wireless headphones can be annoying, especially when it comes to charging. It's yet another device in your life that needs to be charged. However, the Elite 85h tries to break that barrier by having a ridiculously long battery life. The Elite 85h gets you up to 35 hours of battery life on a single charge. Yep, you read that right, 35 hours.
On top of that, the Elite 85h are very comfortable, which is a perfect combination with the ridiculously long battery life. And yes, you can charge and listen to them at the same time.
The sound quality is good. The default sound signature is a bit dull and boring, but fortunately, you'll be able to customize that through Jabra's companion smartphone app. In there, you'll also find options to customize how much ANC you want as well. The ANC is pretty good. Not bad, but not terrible, either. Just good. You'll hear a sizable hum while on flights and some engine noise while taking the bus or train.
The Elite 85h does come with some nifty tricks up its sleeve, though. To turn on/off the headphone, simply swivel the right ear cup. Your audio automagically plays and pauses when you either remove or put the Elite 85h on your head.
Pros:
- Battery life
- Excellent comfort
- Smart features
Cons:
- ANC is average
Best Battery Life
Jabra Elite 85h
Great battery life
With the Jabra Elite 85h, you get incredible battery life and comfort with a customizable sound.
Best Budget Over-Ear Headphones: COWIN E7
Source: Cowin Audio
Most will argue that good ANC on headphones is expensive. However, the COWIN E7 proves that wrong. Starting with battery life, the E7 gets a whopping 30 hours of battery life on a single charge, which is better than some of the more expensive ANC headphones. This will easily last you at least a week with standard usage and will easily be enough for any flights you take.
The ANC on the E7 isn't too bad, either. Surprisingly, it's excellent and compares favorably to the Bose NCH 700s. It gets more consistent noises like engine noise blocked out while struggling with more inconsistent sounds like conversations.
Sound quality is average. It has a boosted bass, which is often overpowering and gives a bit too much thump and rumble. The same can be said about the mid-range where the overall presence is a bit boosted. The treble is super recessed and mostly not present, giving the E7 an overall super dark sound signature. Fortunately, you won't get any fatigue from the treble.
Comfort is relatively good, albeit the headphone is on the heavier side overall. Aside from weight, the E7 will comfortably sit on your head, and we didn't notice any fatiguing or comfort issues when using the E7 for several hours at a time.
Pros:
- Battery life
- ANC
- Comfort
Cons:
- Sound quality
- Heavier than most over-ears
COWIN E7
Excellent battery life at a low price
If battery life and cost savings are your concern, the E7 from COWIN is your best bet.
Best Noise-Canceling Earbuds: Sony WF-1000XM3
Source: iMore
When it comes to earbuds, there aren't many noise-canceling ones out there, let alone ones that include ANC and are true wireless. Yet, here we are with the Sony WF-1000XM3. If you're looking for great ANC and ultra-portability, look no further.
The WF-1000XM3 brings the same great ANC tech it uses in its over-ear equivalent, the WH-1000XM4. While it's not the same, the WF-1000XM3 is easily the best wireless (and truly wireless) ANC earbud on the market. The ANC will surprise you; it can block out a ton of noise, including engine noise and some more inconsistent sounds like walking.
Sound quality is a departure from the classic Sony sound. It's flat and neutral, for the most part, with only minor bumps that most people won't be able to hear. Dynamic range is great, and soundstage is nearly non-existent due to its earbud design.
Comfort-wise, the WF-1000XM3 are good. They're comfortable and won't have an issue staying in your ear, but the design itself is rather large and bulky. Some other truly wireless earbuds can blend in, but people will know you're wearing earbuds with the WF-1000XM3.
Battery life is excellent with up to 26 hours with the included charging case, and up to 6 hours of battery life with the earbuds on its own. The charging case charges over USB-C, and, as most truly wireless earbuds do, the WF-1000XM3 has a fast-charging mechanism that gives you several hours of listening within a 15-minute charge. Unfortunately, the case isn't wireless charging, so you'll need to plug in to charge.
Pros:
- Long battery life
- Class-leading ANC
- Sound quality
Cons:
- Large size
- No wireless charging case
Best Earbuds
Sony WF-1000XM3
Truly wireless ANC
ANC that you can carry in your pocket. The WF-1000XM3 are the best ANC earbud on the market, period.
Source: Rene Ritchie / iMore
If you've been waiting your whole life (or at least a few years) for AirPods that are comfortable to wear for long periods, run, don't walk, to your nearest Apple Store because they've finally made something that doesn't press against your ear cartilage after a half hour.
If, however, you can't stand the feeling of something sitting deep in your ear, stick with your current AirPods. The AirPods Pro have an additional silicone tip that goes deeper into the ear canal, which I know can be uncomfortable for some.
If you want a variety of color options, you're out of luck here. AirPods Pro only come in white. That being said, AirPods have become a status symbol, so you'll be rocking the latest style with the AirPods Pro, a design that is both iconically AirPods, but different enough to make people notice.
Apple has made huge improvements in comfort, quality, and usability, but hasn't managed to do so at a low, low price, so you still have to empty your piggy bank if you want to wear the Apple brand.
Pros:
- H1-chip
- Improved fit
- Hey, Siri compatible
- Wireless charging case
Cons:
- Acceptable audio quality
- Not as useful for non-Apple devices
AirPods Pro
A true companion for your Apple Devices
Everything you love about AirPods with better sound, ANC, and a water-resistance rating of IPX4.
Source: Bose
Unsurprisingly, the best neck buds around come from Bose. The noise-canceling capabilities mimic those of the older generation QC35 IIs. This means that the QC30 performs well, only getting beat by the more recent high-end headphones such as the Sony WH-1000XM4 and Bose's own NCH 700. This means that the ANC is pretty good, but newer headphones will out-class it easily.
Similar to the WF-1000XM3, there aren't many neck buds that also support ANC, so the QC30 was an easy pick. Being a neck bud, the headphone will wrap around your neck with a cable connected to each earbud. The QC30 comes with multiple ear tips in the box, so you should be able to find and ear tip that works for you. When they're in your ear, they work like a charm — no issues with comfort or ear fatigue, even over long periods. And, when you're not using the QC30, you can let them dangle around your neck.
The sound quality is pretty good as expected with most Bose headphones. There's a small boost in the bass to give it a slightly warmer sound signature, but otherwise, it's somewhat neutral and flat. Fortunately, you won't hear any reduction in sound quality when it comes to having the ANC on.
When it comes to battery life, the QC30 perform well for its class. They last up to 10 hours on a single charge, which means you'll be able to get through a full workday and then some without worrying about having to recharge the bud.
Our biggest gripe with the QC30 comes with the Bose companion app. It's not the greatest. You can control the amount of ANC you want with the app, but that only applies to how much isolation you want when the built-in microphone is active. And that's pretty much all you can control.
Pros:
- Battery life
- Sound quality
- ANC
Cons:
- Smartphone app could be better
Best Neckbuds
Bose QC30
Neckbuds with ANC
There aren't many neck buds with ANC out there, so the QC30 from Bose was an easy choice.
Best Budget Neckbuds: Phiaton BT 100 NC
Source: Phiaton
Despite saying that the QC30s are one of the few neck buds out there with ANC, the BT 100 NC from Phiaton is a solid choice if you're on a budget.
The ANC is pretty good for the price. They won't blow you away, but they're great if you're planning to use them on your commute. You'll still hear some environmental noise, but most of it will get blocked out. With ANC enabled, you should expect around 7 to 7 and a half hours of audio playback on a single charge. When not in use, you'll get approximately 15 hours of standby time with ANC enabled. Not the best in terms of battery life, but again great for the price.
The sound quality is good. It has a V-shaped sound signature with emphasized bass and treble, but not overly emphasized where the bass is overpowering and where the treble is just incredibly piercing or sharp. The mid-range does suffer a little bit as that remains neutral and flat, but sounds recessed. Fortunately, you do get aptX (non-HD or LL), which nets you slightly better sound quality and lower latency.
The BT 100 NC also feature vibrations for notifications, which is neat if you don't own a smartwatch or don't always have your phone on you. It lightly buzzes to let you know when a phone call is coming through.
In terms of comfort, they're pretty much as expected when it comes to a neck bud. They do, however, get uncomfortable after several hours of usage with the included ear tips, though. Fortunately, you can use third-party ear tips as the BT 100 NC use standard ear tip sizes.
Pros:
- V-shaped sound signature
- Battery Life
- ANC
Cons:
- Comfort
Best Budget Neckbud
Phiaton BT 100 NC
Budget neckbud tunes
For the price, you can't complain. The Phiaton BT 100 NC perform great or better in all categories.
Bottom line
While there are so many great options listed here, our best pick overall are the Sony's WH1000XM4s. These are the best noise-canceling headphones, with handy gesture controls, great sound, deafening noise-canceling, and long battery life, and that cost a more accessible amount. Plus, they are incredibly comfortable for long periods, making them the best choice for watching videos, gaming, or just listening to some tunes for a few hours. The quality is simply worth the price.
How to choose the best noise-canceling headphones
Source: iMore
Contrary to popular belief, active noise cancelation isn't just for commuting and flying. They're also great in office environments and even as daily purpose headphones if you need to ignore everyone around you.
Choosing the right set of noise-canceling headphones can be hard as it's more than just ANC you're looking at. For example, comfort, whether or not the ANC negatively effects the sound quality, and battery life are huge factors when choosing the right noise-canceling headphone.
Sound Quality
When it comes to audio equipment, sound quality should be in your list of the top three most important things. If you don't like the way it sounds, it won't matter if it's super comfortable or if the battery lasts forever.
In terms of sound quality, we think the AirPods Max edge out the Sony WH-1000XM4; however the Sony cans do have a companion smartphone app lets you customize the sound even further if you'd like more bass, mids, or treble.
The Bose NCH 700s are a runner up, but they're an over-ear headphone. Similarly, they offer a relatively flat and neutral sound signature. However, the NCH 700s have no way of customizing the sound. So, if you don't like them, you're out of luck here.
Bowers & Wilkins' PX make the list purely because of its incredible soundstage and dynamic range for a closed-back headphone.
Best active noise-canceling headphones, ranked by sound quality
- AirPods Max
- Sony WF-1000XM4
- Bose Noise Canceling Headphones 700
- Bowers & Wilkins PX
- Jabra Elite 85h
Comfort
Source: Bose
Comfort is also equally as important because if your headphones sound great but hurt your ears or your head after 20 minutes, what's the point in having them?
Unsurprisingly, the Bose NCH 700s take the top spot. Bose is notoriously known for having great comfort in its noise-canceling headphones, and the latest addition is no exception. With the Bose NCH 700s, you can easily wear them for 10 hours or more without any discomfort.
Despite being earbuds, the Sony WF-1000XM3 are equally as great. The earbuds come with multiple tip sizes, which will help tremendously with finding a level of comfort. Combine that with the compact size of a truly wireless earbud, and Sony has hit a home run here.
Sony had a lot to do when making the WH-1000XM4, and that includes comfort. Its previous ANC headphone, the WH-1000XM2, wasn't all that great when it came to comfort. Fortunately, Sony put in the R&D, and the WH-1000XM4 are surprisingly comfortable now. The ear cups and headband are super soft, and there's not much exposed plastic that touches your head. These are other headphones that you can easily wear for 10 hours or more at any given time.
While the AirPods Max can melt away on your head when you're sitting still, due to their weight, they are quite noticeable when you start moving around. We've been able to wear them for hours at a time with no real issue, but others have complained about the weight of all that metal sitting on your head.
Best noise-canceling headphones, ranked by comfort
- Sony WF-1000XM3
- Sony WH-1000XM4
- AirPods Max
- Bose QC30
Noise isolation
It sounds kind of silly to rank noise isolation on a post about noise-isolating headphones, so we'll keep this short and sweet.
The top three on this list are all really solid. The AirPods Max takes the crown from the Sony WH-1000XM4 with its class-leading ANC, and if you want the best ANC, you go the AirPods Max is your choice. However, the ANC on the Sony WH-1000XM4 are still amazing and with them being hundreds of dollars cheaper, you can't go wrong picking up a pair. The Runner up is the Bose NCH 700s. While not as good as the WH-1000XM4 or AirPods Max, they're pretty close. Whichever you decide to go with is totally up to you and depends on which sound signature you like better.
The WF-1000XM3 are the truly wireless option from Sony and have the same great ANC you get from their over-ear brother the WH-1000XM4. There are differences as the WF-1000XM3 have slightly less ANC than the WH-1000XM4, but this is mostly due to it being a truly wireless earbud versus an over-ear option.
Best noise-canceling headphones, ranked by noise isolation
- AirPods Max
- Sony WH-1000XM4
- Sony WF-1000XM3
Smart Features
Source: iMore
There's not much you can do when it comes to over-ear headphones and smart features. The most over-ear headphones typically do is bundle in a digital assistant of sorts, whether it be Google Assistant, Amazon Alexa, or both.
However, the three that stick out are the AirPods Max, Bowers & Wilkins PX, and Jabra Elite 85h. These headphones feature an auto-play/pause feature, which is rare among noise-canceling headphones, let alone over-ear ones. The Sony WF-1000XM3 are required to have this feature as they are a set of truly wireless earbuds. Of course, the AirPods Max smart feature really comes from having it paired up with an iPhone or other Apple device, so you'll need to already be in Apple's ecosystem to truly take advantage.
The Bose QC30 are awesome, as well. They're neck buds, but the ANC adapts to the environment around you. Combine that with the versatility thanks to being a neck bud, and the QC30 become one of the most portable ANC earbuds on the market.
Lastly, if you're looking for an ANC headphone that does the bare minimum when it comes to smart features, the COWIN E7 are it. They don't have any auto-play/pause features, digital assistant support, or adaptive ANC, but they do feature NFC pairing. If you have an Android smartphone, this makes pairing the headphone to your smartphone super easy.
Best noise-canceling headphones, ranked by smart features
- AirPods Max
- Jabra Elite 85h
- Sony WF-1000XM3
- Bose QC30
Battery Life
Battery life is something that gets wired headphone lovers heated. With a set of wired headphones, you don't have to worry about "another thing to charge." However, if you have long battery life, you forget that you even have to charge the thing in the first place. On a single charge, the best we've seen on noise-canceling headphones.
The top three on our list all get the same roughly 30 hours of battery life on the single charge. If you're looking at battery life specifically, the Jabra Elite 85h, Sony WH-1000XM4, and COWIN E7 all perform excellently in this regard. You'll probably want to look at other potential features between these three headphones.
The Bowers & Wilkins PX barely takes number four with up to 22 hours of battery life on a single charge while the Bose NCH 700s are our fifth pick for having 20 hours of battery life.
Best noise-canceling headphones, ranked by battery life
- Jabra Elite 85h
- Sony WH-1000XM4
- COWIN E7
Microphone Quality
If we're honest here, microphone quality when it comes to noise-canceling headphones kind of suck. Most companies focus on having great microphone quality for the ANC itself or an ambient sound mode, but when it comes to the actual microphone you use to make calls, ANC headphones are decent at best.
That being said, the Bose NCH 700s and the Bose QC30 top this list. Again, the bar is relatively low here, but they top our list when it comes to microphone quality. They're okay when it comes to blocking out environmental noise and isolating your voice, but the person on the other end might have some issues hearing you in louder environments.
The Jabra Elite 85h make this list because they're not half bad when it comes to isolating your voice and reducing the environmental noise. They perform similarly to all of the Bose headphones, but maybe one notch worse.
All other noise-canceling headphones on this list struggle quite a bit when it comes to microphone quality, unfortunately. You're probably better off taking off your headphones and using your phone's built-in microphone and speakers to take calls with everything else on this list.
Best true wireless earbuds, ranked by microphone quality
Source: Bose
- AirPods Max
- Jabra Elite 85h
- Sony WF-1000XM4
Peter Cao likes to spend most of his days enjoying music and playing video games. While at work, he focuses on analyzing, testing, and reviewing all types of headphones and audio gear.
Luke Filipowicz very rarely goes a day without his ears spending at least six hours listening to some sort of headphones. Whether he's gaming, take a conference call, or just listening to his favorite music, headphones are almost always on his head.
You don't need AirPods to have AirPods — check out these copycats
AirPods and AirPods Pro are expensive and although the design was heavily questioned when they first came out, plently of other companies have started to make AirPods lookalikes. Here are the best fake AirPods you can buy right now.
You don't have to love AirPods to love Apple — there are alternatives
Apple's AirPods are a fantastic companion to your iPhone, but that doesn't mean that there aren't other options out there. Here are the best alternatives to AirPods.
Travel in peace with these cases for the Jabra Elite 65t
If you're planning to take your new earbuds on a trip with you, you may want a better case. Whether it's something cheap or a solid-hard case, there are tons of options to pick from. Here are some of the best and highly rated Jabra Elite 65t travel cases for your headphones to check out before your next adventure.
