Mophie's 3-in-1 wireless charging pad for Apple gear is down to $104
By John Levite published
You love Apple, don't you? You've gone in 100% on Apple gear, haven't you? You've got your brand new iPhone, the latest generation of Airpods, and even an Apple Watch gracing your wrist. Well, now you need a way to charge all those things. Well, now you can charge them all on the same pad. The Mophie 3-in-1 Qi-enabled wireless charging pad (opens in new tab) is down to $104.23 on Amazon. This charging pad normally sells for $140 on Apple (opens in new tab) and on Amazon, but today's deal is a nice low price. It's one of the best deals we've ever seen and the first discount in several months.
Mophie 3-in-1 Qi-enabled wireless charging pad for iPhone, Airpods, and Apple Watch (opens in new tab)
Did you invest in a fancy Apple iPhone, Airpods, and an Apple Watch? Mophie's charging pad is one of the only ways to wirelessly charge all three of them at once. Even works through cases up to 3mm thick.
Mophie Dual Wireless Charger
$15.99 $69.99 Save $54
This premium wireless charging pad can power up to three devices at once using its dual wireless charging spots and built-in USB-A port. Use the following promo code during checkout to snag today's low price.
mophie Juice Pack Air - Mfi Certified - Wireless Charging - Protective Battery Pack Case for Apple iPhone Xs Max - Red
$47.50 $49.99 Save $2
Mophie Charge Stream pad+ 10W Qi-enabled wireless charge pad
$22.81 $59.95 Save $37
mophie Charge Force Case with powerstation External Battery Pack for Samsung Galaxy Note 8 - Black
$19.95 $29.95 Save $10
powerstation with Lightning Connector - Made for iPhone, iPad, AirPod, and Other USB Devices - Black
$20.00 $49.95 Save $30
We reviewed Mophie's 3-in-1 charger when it first came out and gave it 4 stars out of 5. Our review said, "It's quite a relief to be able to clear three different chargers and that tangle of cables off of your nightstand or desk and replace it with just one gorgeous accessory. Everything you need is right in the box, you don't need to hunt down additional cables or charging brick. Just set it on your table, plug it in, and plop down your iPhone, Apple Watch, and AirPods for a charge."
In fact, this pad provides Fast Charge for all those devices, too. So you'll get the best possible speeds in one nice convenient place. It can handle cases up to 3mm on your gear, too. The ultrasuede finish adds a nice bit of style for you, especially if you're keeping the pad in a visible spot like a nightstand or end table. The design also keeps your Watch elevated so you can use it with Nightstand Mode on. The indent for your Airpods ensures a dedicated charging spot that begins on contact, but it also keeps your Airpods out of the way of the Watch's screen.
Mophie covers the pad with a two-year warranty.
