Eton Mobius battery cases for iPhone features solar charging
We had a chance to take a close look at the Eton Mobius battery case for iPhone 4 and iPhone 4S here at CES 2012. This case not only features an 1800 mAh battery backup system but a solar charging panel on the back as well. Set your phone face down to gain a solar charge.
While Mophie and Incipio also make battery backup cases, Eton is unique in how they designed the case. Instead of having to force your phone into a slide case which may cause damage to the dock, the Mobius case slides to allow easy placement. Once your phone is in the case, snap the dock connector in place.
The Eton Mobius is currently available for $80 USD.
There are 10 comments. Add yours.
This solar case oozes and drips of awesomeness.
I just hope that's gorilla glass over the solar panels.
can i marry it? want it!
Solar panels are cool.
Pretty cool idea, how about one without the extra battery though.
Perfect for Coachella!
My daughter has an Android that has a solar pannel on its back. It really extends the battery in between charges. I am going to get one!
too big!...on the back side.
Hey Beavis... they said backside.... Heh-heh... heh-heh...
Prince will Quit... Foreverwww.musicwillchangeforever.com
Nice post. I used to be checking continuously this weblog and I'm impressed! Very useful info particularly the last section :) I handle such information much. I was looking for this certain information for a very long time. Thank you and best of luck.
