Incipio NGP Semi-Rigid Soft Shell Case for The new iPad only $19.95 [Daily deal]
For today only, the iMore iPad Accessory Store has the Incipio NGP Semi-Rigid Soft Shell Case for The new iPad on sale for only $19.95! That's a pulse-pounding 33% off! Get yours before they're gone!
The NGP Semi-Rigid Soft Shell Case safeguards your The new iPad with a semi-ridi polymer shell. Featuring custom-cut holes, you'll have access to your The new iPad camera hole and other functions.
NGP stands for "Next Generation Polymer" - a semi-rigid dense polymer. The NGP material is malleable enough to slip around and snugly hold your The new iPad, but firm enough to withstand impacts and scrapes.
The touchscreen of your The new iPad is left exposed for complete access. The NGP wraps the front edges of this device giving it added protection and an extra lift. As sleek as it is function, NGP makes a great choice.
This case provides full coverage, and low-profile protection while leaving all necessary ports exposed for easy access to essential functions. There is no need to remove the case when charging or syncing to your computer.
Features:
- Next Generation Polymer case
- Semi-rigid
- Snug around The new iPad
- Custom fit for The new iPad
- Cut outs for all device features
- Low-profile
Shop Incipio NGP Semi-Rigid Soft Shell Case for The new iPad now!
Comments are closed
