This affordable LED backlighting kit is discounted to just $10 via Amazon
Setting up backlighting behind your TV or computer desk isn't as much of an expense or hassle as you might think. Right now the Linkind RGB Waterproof Light Strip Kit (opens in new tab) is down to only $9.90 at Amazon when you use promo code ZLLJBNFK during checkout. That saves you $12 off its price otherwise and brings this kit lower than it's ever reached without a code before.
Image (opens in new tab)
Linkind RGB Light Strip Backlighting Kit (opens in new tab)
Linkind's 16.4-foot LED light strip can switch between various colors, light modes, and it's even dimmable. It can be cut to size too and is easy to install using the accessories you'll receive.
(opens in new tab)
$9.90 $21.99 Save $12
This 16.4-foot LED light strip can switch between various colors, light modes, and it's even dimmable. It can be cut to size too and is easy to install using the accessories you'll receive.
This kit comes with a 16.4-foot LED strip which can be cut down to size as needed. It's capable of switching between 8 solid color choices, as well as 3-color, 7-color, and 16-color options for a multi-colored look. There are various modes to switch between as well, including static, flickering, meteor, and more. However, it's important to know that some of the modes will be affected if the strip is cut.
One of the best features of this light strip kit is its IP65 rating; the strip is waterproof giving you the ability to use it indoors or outside without worrying about the weather ruining it. Screws and clips for reinforcement are included with the purchase so you can ensure it's properly held down when used outside.
Unlike some other backlighting options at Amazon, this model can only be controlled using the remote control that comes with its purchase. If you're looking for a smarter model which can be controlled or scheduled to turn on and off using your phone, this Govee Backlighting Kit (opens in new tab) is a better match and available for less than $30 right now.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial (opens in new tab) to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
Alex Smith
