The Anker PowerCore Fusion 5000mAh dual USB portable charger is down to $25.49 on Amazon, and this price is available in both white and red. Black is still selling for around $30, which is the street price for these wall adapters. They were actually selling as high as $36 for the last week or so, too, so this is an even better discount when compared to that. They do not drop directly much. Usually you need a code or something like with most Anker devices, so it's nice to just see the straight savings here with no hoops to jump through.
Charge up
Available in white and red. Combines a 5000mAh portable battery you can take with you with a wall adapter that lets you plug in and charge anywhere. Has two ports for charging multiple devices and LED indicators for battery life.
$25.49 $30.00 $5 off
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics and can let it in when you need to hear. Battery lasts up to 40 hours with ANC on and 60 hours with it off. First in the series to use USB-C.
Anker Soundcore Liberty Air X true wireless earbuds best buy
These earbuds include expertly-tuned graphene drivers. They have exceptional sound accuracy and great clarity thanks. The aptX codec helps deliver music wirelessly without interference. Get 7 hours on a single charge and 28 hours with the case.
Anker charging cables, wall chargers, and solar power banks
Never go without power. Get an Anker power strip with a USB-C port, a USB-C to USB-C charging cable, a USB-C wall charger, or even a 10000mAh portable battery charger with a built-in solar panel so you can get power even in the great outdoors.
Anker wall chargers, USB-C cables, wireless charging pads, and more
The sale includes USB-C to USB-C cables for as low as $11, a five-port wall charger with Quick Charge 3.0 ports for just $26, and even an Anker power strip that includes multiple USB ports and AC outlets for $25 off. All prices are good today only.
Anker Roav C2 Pro dash cam black
Has a 145-degree wide-angle lens that can view up to four lanes of traffic. Includes a Stony Starvis sensor and NightHawk tech for capturing everything, even license plates, day or night. Has a 3-inch display and built-in G sensor.
It's called the Fusion because it merges together two very important functions: a portable battery charger and a plug-in wall adapter. The portable battery charger part includes a built-in 5000mAh battery you can use anywhere. The LED indicators on the side will show you much juice is left.
If you get to a point where you've got a wall outlet at your disposal, you can just plug this charger in and use it to pull power straight from the outlet. That's convenient for both recharging the portable battery and continuously charging your favorite devices. Anker's PowerIQ and VoltageBoost technologies help detect what's been plugged in and deliver the fastest possible charge, although it doesn't support other things like Quick Charge.
The device has two USB-A ports you can use with any compatible device. It recharges via micro USB and comes with a cable for that. It also comes with an 18-month warranty and a travel pouch.
