Best smart power strips 2023
If you want to add some smart home accessories to your home but don't want to replace everything just yet, getting a smart power strip could be the best thing you can do. These smart Wi-Fi-enabled power strips give you the ability to control, monitor, and manage all of your devices, anytime and anywhere. Most of these smart power strips also have built-in surge protection to keep you and your devices safe. If you're looking for the best smart power strip, our top recommendation is the APC Smart Plug Surge Protector since it combines smart home control with the legendary power protection that the brand is known for. However, all of the other options on this list are also great.
Best Overall: APC Smart Plug Surge Protector
The APC Smart Plug Surge Protector combines state-of-the-art electrical protection with the convenience of smart outlet control. APC takes protection seriously and backs up its surge protector with an equipment protection policy that will reimburse customers for any losses. It also offers a lifetime warranty.
While the APC Smart Plug Surge Protector is only compatible with Amazon Alexa for voice control, it can work with both iOS and Android via the APC Home App. This protector includes a total of six outlets, three of which are smart, and status indicator LEDs offer additional peace of mind when it comes to the protection of your devices. This is an excellent solution for connecting the best HomeKit cameras.
To top things off, the APC Smart Plug Surge Protector includes four USB ports, which add a little extra convenience. This helps to reduce the number of bulky charging blocks that you may have, making it perfect under a desk or nightstand.
Reasons to buy
Reasons to avoid
APC's strip works to keep your gear safe. Three smart outlets, three normal outlets, and four USB ports make it a great pick.
Best for HomeKit: Eve Energy Strip
The Eve Energy Strip provides a sleek, modern take on the traditional power strip. An aluminum silver and black frame with its three outlets make the energy strip stand out from the competition and is something that you may not want to hide under the desk. Each of the Eve Energy Strip's outlets works independently from each other through the iOS Home app, the Eve for HomeKit App, Siri, and with the physical buttons on the device itself.
Thoughtful touches such as the generously spaced, 90-degree outlets make worrying about fitting bulky adapters in a thing of the past. Gentle LED indicator lights will not light up your space at night, and a child lock prevents unwanted cases where an outlet is shut off by accident. The Eve Energy Strip can also be set to randomly turn on and off each outlet to simulate presence within your home even while you are out.
Eve Energy Strip — Connected Triple Outlet
Reasons to buy
Reasons to avoid
Eve's strip comes in an aluminum frame that is sure to last for years. Certified protection ensures that your gear will be safe.
Best Number of Outlets: Kasa Kasa Smart HS300 Plug Power Strip and Surge Protector
TP-Link's Kasa Smart Wi-Fi Power Strip provides a total of six smart outlets and three USB ports, enabling it to handle as many devices as you can throw at it. Each outlet can be individually controlled through Alexa or Google Assistant, via TP-Link's App, or even by pressing a conveniently located button.
The Kasa Smart Wi-Fi Power Strip also includes power monitoring and scheduling options to help keep your costs down. A flat plug at the end of the power strip allows placement neatly behind furniture, and it follows a traditional power strip design, making it blend into your space without screaming smart device. Unfortunately, there are only small spaces between the outlets, which might make plugging in your devices difficult.
Reasons to buy
Reasons to avoid
This strip has six smart outlets enabling the ultimate in control. Surge protection and energy monitoring make it a solid choice.
Best Value: Linganzh Smart Power Strip
Linganzh's Smart Power Strip is an affordable option for those who are looking for just the basics in smart control. Even with its lower cost, this strip offers four outlets that work independently, as well as basic surge protection.
Wi-Fi connectivity enables the Linganzh Smart Power Strip to be set up in a matter of minutes, without the need of an additional smart home hub. Amazon Alexa and Google Assistant are all supported by the power strip making it a smart, future proof option. However, because you're paying less, you'll have to miss out on USB ports.
Linganzh Smart Power Strip and Surge Protector
Reasons to buy
Reasons to avoid
This low-cost power strip covers all of the basics. Surge protection and four smart outlets make it suitable for most tasks.
Best Outdoor Power Strip: Kasa Smart KP400 Outdoor Smart Plug by TP-Link, Smart Home Wi-Fi Outlet
The Kasa Smart KP400 Outdoor Smart Plug is one of the best smart power strips that you can use outdoors. It is small and compact, so it won't look bulky and out of place outside of the house. It provides you with two outlets for all of your outdoor electronic needs, such as Christmas or landscape lights, swimming pumps, speakers, and any other appliances that you need to plug in.
What makes this one smart is that it connects to your Wi-Fi network with a range of up to 300 feet, which is more than enough for most households. There are LED lights on the unit to indicate when it's properly connected, and it is compatible with Alexa and Google Home. It supports grouping as well, so if you have more than one of these, you can organize them as you see fit, right from your smartphone. The Kasa Smart KP400 is also weather resistant with an IP64 rating, so it'll withstand any weather condition you're in.
Reasons to buy
Reasons to avoid
It's small enough to fit anywhere outside, allowing you to control two devices with full weather resistance and voice control.
Plug in with the best smart power strips
When you have a smart power strip, you get both convenience and functionality in a single, easy-to-use package. With added features like energy monitoring, it also becomes much easier to determine what devices are draining power, and managing everything remotely with a tap or your voice is just so handy to have. And surge protection comes with the best smart power strips and smart plugs, which makes them even more of an essential tool to have around the house. While these are the best overall smart power strips, we also have some of the best HomeKit power strips if you want more HomeKit integration.
If you are in the market for the absolute best smart power strip that has a solid, durable design with smart capabilities and protection, you just can't beat the APC Smart Plug Surge Protector. This power strip includes APC's device protection policy and features little things such as handy USB ports that make it stand out from the rest. And even though it is only compatible with Amazon Alexa, you can still use the APC Home app on your iPhone for full control. The fact that it has a total of six outlets, with three of them being smart, as well as four USB ports, means you have a ton of flexibility.
iMore Newsletter
