Source: Leviton
Best wall outlets with USB charging ports iMore 2022
Running out of available USB ports is an absolute pain. The marrying of electrical wall outlets with USB ports is sheer genius. Being able to charge your iPhone and iPad, plus still have room to plug in lights, makes life easier. My favorite wall outlet with included USB ports is from Topgreener. It's an easy-to-install outlet with one USB-C port and one USB-A port. What are the best wall outlets with USB charging ports? Read on! I've rounded up a must-read list.
- Best overall: Topgreener TU21558AC
- Best value: OviiTech 2-pack
- Best color choices: Leviton T5632-W 15-Amp Charger/Tamper Resistant Duplex Receptacle
- Best bundle: SZICT USB Wall Outlet 4-pack
- Best low standby power consumption: ELEGRP USB charger wall outlet
Source: Topgreener
If you're going to upgrade your outlets, it only makes sense to match new technology that you already own. Topgreener's USB wall outlet includes ultra-high-speed Type-A and reversible Type-C ports, plus two standard electrical sockets. For safety, the outlets are tamper-resistant and designed to prevent unwanted objects from being inserted.
This is a solid choice for small Type-C electronics like smartphones, fitness chargers, Nintendo Switch, and headphones. It does not support charging bigger items like laptops, nor does it have Fast Charge tech, so look elsewhere if that's what you need.
This kit includes the wall outlet and needed screws. It's available in white, gold, beige, and gray, so you can match it to your existing wall plate or paint color. If you have both USB-A and USB-C tech, this easy-to-install wall outlet from Topgreener is a no-brainer.
Pros:
- Supports USB-C and USB-A
- Tamper-resistant
- Protection against overcharging
- Four color choices
Cons:
- Does not support Fast Charge technology
- Cannot charge USB-C laptops
Source: Oviitech
Turn a standard outlet into a high-speed charger with OviiTech's budget-friendly wall socket and USB outlet combo. This attractive model is available in white or gold directly into the wall replacing a standard duplex outlet and is compatible with side and back wiring.
The USB ports are vertical, so you never need to crisscross cords to power your devices or use the outlets. The USB ports are compatible with USB 1.1, 2.1, and 3.0 devices and automatically adjust power output. This setup comes with an outlet, screws, and a screwless wall plate.
It's worth mentioning that this combo is larger than a standard receptacle, so you may need to work in a larger electrical gem box. Also, there's a logo on the outlet. It's visible, but it doesn't stick out, especially when the outlet is in use. If you're working with a tight budget, the 4.2A wall outlet with USB charging ports from Oviitech is worth every penny.
Pros:
- Screwless wall plate
- Easy to install
- Inexpensive
- Vertical USB ports
Cons:
- Larger than a standard receptacle
- The cover plate has a logo
Source: Leviton
Billed as the "highest power device on the market," the wall outlet from Leviton includes two smart chip-powered USB ports that recognize the charging requirements of any device attached. For you, that means the charge is optimized for whatever you may plug in. The USB ports' vertical placement gives you maximum space for maneuvering cords and doesn't interfere with appliances using the plugs.
Installation is a breeze, too. The Leviton receptacle is back and side-wired and works well with a variety of wiring setups. The Leviton fits standard wall boxes and is compatible with Decora and Decora Plus screwless wall plates. You can grab this wall outlet with USB charging ports in one of six color choices to match your decor.
The Leviton outlet doesn't include a faceplate, so you'll need to pick that up separately. Also, this unit doesn't sit flush with standard wall plates. The AC and USB ports stick out a little from the wall plate. This isn't a bad thing, but it is worth noting. For most, the Leviton is the simplest unit to install and, with high-powered smart technology, the one most likely to work with all your devices.
Pros:
- Easy to install
- Available in six colors
- Vertical USB ports do not interfere with plug placement
- Tamper-resistant
Cons:
- Does not include a faceplate
- Doesn't fit flush with standard wall plate
Source: Amazon
When you want to outfit an entire room or several outlets in your home, you want this four-pack bundle from SZICT. It easily makes our list of the best wall outlet with USB charging ports. Each USB-A port outputs 4.2A, and the vertically arranged USB outlets give you plenty of room to plug other things in without getting cables tangled.
These are child-safe and tamper-resistant. It's impossible to insert items into the holes that do not belong. That makes these outlets perfect for children's rooms or any other area of the house.
This kit comes with polycarbonate wall plates that wipe clean and all the necessary mounting hardware. These are deep outlets that won't fit all spaces, so it's wise to measure your box before purchase. For those who want to upgrade several outlets at once, this four-pack from SZICT is an inexpensive way to get the job done.
Pros:
- Four outlets included
- Childproof design
- 4.2A
- Wallplates included
Cons:
- Deep box may be a tight squeeze for some spaces
Source: Amazon
Phantom power consumption is a thing, and ELEGRP wants to make it a thing of the past. Boasting 87-percent energy efficiency and low standby power consumption, this tamper-resistant receptacle is one smart cookie! Smart chip USB 4.0A ports identify what's plugged in and adjust the output accordingly.
This outlet kit supports side and back wiring and fits standard wall boxes and wall plates. Extra safety features like overvoltage protection, overload protection, and short circuit protection are built into this flame-resistant outlet.
My only complaint is that there's a logo on the outlet. It's less obvious in the grey color, but go with the black or brown, and the writing stands out. If this doesn't bother you, ELEGRP is a smart chip outlet that works quickly and efficiently.
Pros:
- Available in two colors
- Excellent safety features
- Extremely low standby power consumption
- Energy efficient
Cons:
- Logo on wall plate
What's the best wall outlet with USB charging?
Whether you're plugging in an iPhone with a USB-C to Lightning cable or wanting to charge a tablet next to the couch, wall outlets with USB charging ports make life hassle-free.
We think that upgrading your outlets and ridding yourself of pricey USB adapters shouldn't be difficult. The Topgreener TU21558AC makes the process less headache-inducing with a receptacle that fits standard wall boxes. This is a high-speed wall outlet with one USB-A port and one USB-C port, so it can handle pretty much anything you throw at it.
The USB ports have a combined power of 5.8 amps and are positioned vertically, which is easier on charger cords and never interferes with appliances already plugged into the electrical outlets. If what you need is a powerful wall outlet with robust features from a brand that's known for quality goods, this is it!
Jodi Owan is a freelance writer and photographer who has been published in print and online. When not hiking through the backwoods with a camera, she can be found testing and writing about technology. Find her on Instagram and her website.
Ditch the dongle with these great docking stations for your MacBook Pro
Need to connect all the things to your MacBook Pro with USB-C ports? Get yourself one of these docking stations and ditch the dongles!
Make sure you have all the ports you need for your Mac with a USB-C hub
The current MacBook Pro sports at least two, and up to four Thunderbolt 3 ports, but that's all. What do you do if you need more ports? Get a hub!
Quickly charge your iPhone 12 with these fantastic USB-C wall adapters
The best iPhone 12 chargers will let you charge your iPhone super fast. If you plan on getting any of the newly-released iPhone 12 models, you'll want one of these chargers.
