More and more of our devices are starting to adopt USB-C, from our phones to our laptops, so it makes total sense to consolidate our charging gear so we don't have to carry multiple bricks and cables around each day. Anker's 60W PowerPort Atom III USB-C wall charger can be used to juice up all manner of devices and, right now, you can get it with a $16 discount at Amazon. All you have to do is enter code SDANKERPD during checkout to see the price fall to a new low. The discount only applies to the black version at present.
Fast charge
Anker PowerPort Atom III 60W USB-C Charger
This is the lowest we've seen Anker's new USB-C charger go. With a 60W output, it can power everything from your phone to your laptop and, thanks to GaN tech, it's much smaller than most power bricks. Clip the on-page coupon for the best price.
$25.99 $41.99 $16 off
With coupon: SDANKERPD
Though this well-reviewed wall charger is equipped with just one USB-C port, it has a 60W output so it can be used with a variety of device types including larger tech gear like laptops. Even though it packs the same sort of power as a 13-inch MacBook Pro charger, it has a 35% smaller form factor making it perfect for travelling with. It also has a folding plug. Unlike previous wall chargers, this one is powered by gallium nitride which generates less heat and allows Anker to make it much more compact.
With so many devices going all-in on USB-C, you can future-proof yourself with this high-performance wall plug and reduce travel clutter at the same time. If one port is not enough for you, you can also snag a 2-port version, though that model is only $3 off. It's worth noting that neither option includes a USB-C cable so you'll need to use your own or add one to your order.
