With everything you can do on your phone these days, and all of the essential things we need them for now, it's imperative that your phone doesn't run out of juice while you're out and about. Because of this, it's well worth picking up a portable power bank to take with you.
Fortunately, you don't have to spend a ton of money on one. In fact, you can get this EasyAcc 6000mAh power bank for under $10. Simply add it to your cart and enter code 82C2PUXH during checkout and you'll see its $17 price cut in half, dropping it to just $8.49. We've never seen it go lower and, at this price, it's a no-brainer addition to your daily carry. It'll ship for free with Amazon Prime or on orders over $25, too.
Take it with you
EasyAcc 6000mAh Power Bank with Lightning Cable
A good power bank is essential but you don't have to spend a ton of cash to pick one up. This 6000mAh charger is slim enough to fit in your pocket, but still packs enough battery to charge your phone at least once over via Lightning or USB.
$8.49 $16.99 $8 off
With coupon: 82C2PUXH
While this power bank is slim enough to fit in your pocket, it's still got a decent capacity for day-to-day use. At 6000mAh, it will charge most iPhone models around two times before the power bank needs to be connected to power again. Granted, that's not going to get you through a three-day hike, but it's not designed to. This is the sort of power bank you'd take with you everywhere in a purse or jacket pocket.
It's got an integrated Lightning cable meaning you don't have to remember to bring one of those along and its additional USB port allows you to split the power with a pal. That Lightning cable is MFi-certified too so you won't get that annoying dialog popping up saying the accessory is not supported. There's also a built-in flashlight in case you need a light source in a pinch. Existing owners rate this power bank highly with an average score of 4.2 out of 5 stars.
