Whether you need a powerful wireless charging car mount or a beautiful aluminum stand to display your iPhone, Apple Watch, and AirPods altogether, you can save 35% on products from Omoton at Amazon today. Once you click that link and decide to add something to your cart, the price is taken off automatically during checkout. The discount will only apply to one item even if you add more than one to your cart from the same link.
You can actually save a little bit extra on a couple of the products for sale here, too. For example, this Omoton 3-in-1 stand has a 10% off on-page coupon. Once you add it to your cart via the 35% off promo above, you can clip the extra 10% coupon in your shopping cart. That brings the total down to $8.79 from $16. You can also save an extra 5% in similar fashion on this version of the 3-in-1 stand, which is updated to be compatible with a wider range of devices including the newer AirPods.
Mount up!
Omoton stands, mounts, and car chargers
The wireless charging car mount provides up to 10W charging power and is compatible with any Qi-enabled device, including the iPhone or Android smartphones. The 3-in-1 stand can hold your iPhone, Apple Watch, and AirPods. Scratch resistant aluminum.
35% off Various Products
The Omoton wireless charging car mount is down to $12.74 form a street price of $19 with this sale. This is a Qi-certified wireless charger that supports a max of 10W fast charging, which works with Samsung phones like the Note 10 Plus, Galaxy S10, and more. You can also get 7.5W charging with your iPhone. It includes an automatic clamp that can be worked with one hand, and there's even an RGB LED ring that lets you know when there's an issue. You can install it on your windshield, dashboard, or an air vent, and it will charge even if your phone has a thick case on it.
The updated 3-in-1 stand comes in Black, Rose Gold, and Silver. While designed specifically to hold the iPhone, Apple Watch, and Apple AirPods, the phone holder is actually adjustable. That makes it compatible with any smartphone really. The Apple Watch holder will fit any series between 1 and 5 and any size between 38mm and 44mm. Plus, the scratch-resistant case designed to hold the AirPods works with AirPods 1 or 2.
You can actually fold the entire case down if you want to take it with you on the road. The viewing angle can also be adjusted so you can use your phone hands free. Keep in mind, this is just an aluminum stand. It's a pretty aluminum stand, but that's all it is. There is no wireless charging or anything like that, so you will need to provide your own cables.
