HooToo's 6-in-1 USB-C hub and adapter has dropped to a low price of $17
The HooToo USB-C hub multi-port adapter is down to $16.99 right now at Amazon. This is a brand new low price for the 6-in-1 USB-C adapter. It has been selling around $20 recently but it was as high as $36 in April, which puts its street price somewhere in between those two. But again, it has never dropped below $20 so today's deal is the price to pay attention to.
Add a lot more functionality to any laptop with a USB-C port. Turns that one USB-C into a 4K HDMI port, three USB 3.0 ports, an SD card reader, and a 100W PD charging port. Compatible with Windows, Mac, Unix, Chromebook, and almost all USB-C devices.
The hub is compatible with pretty much any device that uses USB-C, including tablets like the iPad Pro. It will support Mac, Windows, Unix, and Chromebook OS. Whatever operating system you use and whatever machine you use should work as long as you have a USB-C port.
This is a 6-in-1 adapter that can really add some functionality to your USB-C port. That's especially important if you don't have a lot of extra ports on your machine, or, you know, any extra ports at all. The hub turns your single USB-C port into a 100W Power Delivery charging port (so you don't lose access to powering your device), a 4K HDMI port, three USB 3.0 ports, and an SD card reader.
Use the HDMI port to output video in 4K resolution at 30Hz or 1080p at 60Hz. Use it for projecting video and presentations at work or for expanding your screen real estate onto a larger monitor. The SD card works with transmission speeds up to 480 Mbps. And the charging port gives you the fastest possible charge for your USB-C device.
The three ports have USB 3.0 speeds and can transfer files up to 5 Gbps. These ports cannot charge anything. They are for data transfer only. However, that gives you plenty of options for connecting extra storage or moving files off a thumb drive and things like that.
