The LG 27GL850-B 27-inch Ultragear Nano IPS gaming monitor is down to $446.99 on Amazon. This monitor usually sells for around $500, and it has hardly ever dropped from that price. The only other time it dropped in price was a similar deal to this one that we shared in late January. Since then, though, it bounced back up to $500 or went out of stock altgoether. Grab it while you can before this deal disappears again.
Play on
LG 27GL850-B 27-inch Ultragear Nano IPS G-Sync 1440p gaming monitor
Comes with a 1440p pixel resolution, 144Hz refresh rate, and a 1ms response time. The IPS panel has superior color and viewing angles. Also has adaptive sync that works with AMD and Nvidia. Wall mountable and has an ultra-thin bezel.
$446.99 $500.00 $53 off
No lie, I have been keeping an eye on this monitor since before its release last July. I even bought the budget version, the LG 27GL83-A over Black Friday. These monitors have been so popular since release thanks to the balance of price and features that just staying in stock has been difficult enough.
Get an iPhone SE with Mint Mobile service for $30/mo
If you're a gamer, the specifications on this monitor are ideal. It's a 27-inch screen with 2560 x 1440 pixel resolution, a 144 Hz refresh rate, and a 1 ms response time. It also uses an IPS panel, which is crazy given that IPS panels usually have much slower response times. Some reviews have called it one of the fastest response times ever measured for a panel like this thanks to LG's Nano IPS technology.
With those stats and the adaptive sync technology built in, you won't notice any motion blur while gaming. It defaults to AMD FreeSync tech, which works with your AMD graphics card to reduce screen tearing. However, it's also officially compatible with Nvidia G-Sync, so you can use this with your Nvidia graphics card as well. Just plug in via DisplayPort to get that G-Sync tech working along with the best 144 Hz refresh rate.
It comes with an ultra-thin bezel and a stand that is tilt, height, and pivot adjustable. You can also forego the stand for a wall or arm mount with the Vesa 100 x 100mm standard.
