For someone who never needs just one power outlet, Anker's USB Power Strip 2 could be the next essential accessory you add to your packing list. This compact power strip is fitted with two AC outlets and two USB charging ports so you can power up four devices simultaneously using just one wall outlet, and its USB ports even deliver an optimized charge based on what type of device is currently plugged in.
While the USB Power Strip 2 generally sells for $24 at Amazon, right now you can pick one up on sale for just $15.99. This $8 discount marks the best price it's ever reached and a deal you won't want to miss out on.
More Power To Ya
Anker 24W Powerport Strip 2 Mini Power Strip
Score more space to power up with Anker's USB Power Strip 2, featuring two high-powered USB charging ports, two AC outlets, and a slim power plug. Today's sale drops its price to the best we've seen so far.
$15.99 $23.99 $8 off
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics and can let it in when you need to hear. Battery lasts up to 40 hours with ANC on and 60 hours with it off. First in the series to use USB-C.
Anker Soundcore Liberty Air X true wireless earbuds best buy
These earbuds include expertly-tuned graphene drivers. They have exceptional sound accuracy and great clarity thanks. The aptX codec helps deliver music wirelessly without interference. Get 7 hours on a single charge and 28 hours with the case.
Anker charging cables, wall chargers, and solar power banks
Never go without power. Get an Anker power strip with a USB-C port, a USB-C to USB-C charging cable, a USB-C wall charger, or even a 10000mAh portable battery charger with a built-in solar panel so you can get power even in the great outdoors.
Anker wall chargers, USB-C cables, wireless charging pads, and more
The sale includes USB-C to USB-C cables for as low as $11, a five-port wall charger with Quick Charge 3.0 ports for just $26, and even an Anker power strip that includes multiple USB ports and AC outlets for $25 off. All prices are good today only.
Anker Roav C2 Pro dash cam black
Has a 145-degree wide-angle lens that can view up to four lanes of traffic. Includes a Stony Starvis sensor and NightHawk tech for capturing everything, even license plates, day or night. Has a 3-inch display and built-in G sensor.
Anker's USB Power Strip 2 will be one tech accessory you won't want to travel without, as it allows you to turn one wall outlet into four ways to charge. You can leave your bulky USB wall adapters that take forever to power you up at home. These two high-powered USB charging ports have a max 24W output and provide an optimized charge based on the device that's plugged in, while the AC outlets have a max 1250W output. There's no surge protection included which makes this power strip a viable option to bring along on a cruise, too.
Its power plug is designed to be slim enough to plug in behind furniture and other tight spaces, and there's even a non-slip base so the power strip won't slide around on your furniture while it's in use. Anker included a few safety precautions including a thick, rubber-coated power cable, fire-retardant casing, and internal safety shutter which prevents random objects from being stuck into the outlet's holes. You'll also receive an 18-month warranty with its purchase.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime account. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum. You'll also gain access to benefits such as the Prime Video streaming service, exclusive members-only discounts, and more.
