Source: Zagg
Best triple wireless charging pads iMore 2022
Now that charging has become as simple as laying down your device on a surface and letting it juice up, investing in triple wireless chargers is an efficient way of keeping your growing number of Qi-enabled devices powered up. Topping our selection of the best wireless charging pads is the ZealSound Wireless Charging Pad. This stylish leather pad is compatible with a variety of Qi-enabled devices and powers three devices simultaneously.
- Best Overall: ZealSound Wireless Charging Pad
- Best for Apple Users: mophie 3 in 1 Wireless Charge Pad
- Best Value: Kekodeepfun Wireless Charger
- Best Build Quality: Yootech Fast Wireless Charger
- Best for Fast Charging: Ruishion Wireless Fast Charging Pad
Source: Amazon
ZealSound is known for making quality audio accessories like microphones and earbuds. The ZealSound Wireless Charging Pad is a great addition to their product portfolio, and it's an absolute hit. The pad is compatible with most Qi-enabled devices and charges through cases not thicker than 4mm. Delivering the standard 5W is a safer option for those keen on prolonging battery life.
To be able to power three devices simultaneously, any charging unit is bound to get hot. However, the ZealSound pad integrates intelligent temperature control into a slim profile (0.24 inches) to protect your devices against overheating, short-circuiting, and power surges.
Pros:
- Efficient cooling system
- Ultra-slim profile with stylish leather finish
- Compatible with all Qi-enabled devices
- 5W standard charging prolongs battery life
Cons:
- Doesn't support fast charging
Best for Apple Users: mophie 3-in-1 wireless charging pad
Source: Zagg
The mophie 3-in-1 wireless charging pad is Apple's official triple wireless charger, and a close alternative to the much-hyped but canceled Airpower. Upon review, we found that the mophie 3-in-1 charging pad has a super stylish suede fabric finish that complements both home and office decor. Featuring three dedicated charging spots for AirPods, the Apple Watch, and an iPhone or Android phone, it is a super convenient way of juicing up all your everyday-carry Apple gadgets from a single unit.
Since wireless charging in iPhones maxes out at 7.5W, the pad is engineered to safely deliver up to 7.5W, ideal for a safe, fast wireless charging experience. Also, the pad is compatible with light Qi-enabled cases less than 3mm thick. The overall design of the Apple Watch charging connector is designed to hold the watch at an ideal angle so you can enjoy the nightstand mode — not even the AirPods charging spot obstructs the view.
Pros:
- Optimized for Apple devices
- Supports fast wireless charging
- Premium sued finish
- Supports Apple Watch nightstand mode
Cons:
- A single dedicated phone charging spot
Source: Amazon
Even though the name sounds like a tongue-twister, this triple wireless charging pad is simple, sleek, and works like a charm. The pad is super compact and well organized with designated charging spots for the Apple Watch Watch, AirPods, iPhone, or other Qi-enabled devices. The pad's connector spot works with all generation Airpod cases, saving you tons of dollars in acquiring a separate Lightning cable or wireless charging case for the AirPods.
The pad has a 10W, 7.5W, and 5W output capacity, which means it can deliver fast and standard wireless charging speeds to all Qi-enabled devices depending on their capacity. It's also pretty safe thanks to an advanced temperature control system that controls overcharging, discharging, and overheating. There is a perfectly cut-out slot under the back cover meant to fit the watch charging cable (not included) for a seamless wireless charging experience.
Pros:
- Compact with designated charging spots
- Compatible with AirPods 1, 2, and Pro
- An advanced temperature control system
- Powers all three accessories simultaneously
Cons:
- Powers one phone at a time
Source: Yootech
Charging three devices at a go sounds like an overload for a regular charging pad. Therefore, having one built to the standard ensures you fully harness the convenience of charging multiple devices concurrently. The Yootech is well built and enhanced with an intelligent cooling fan and a heat-emission hole to keep the wireless charger running at a lower temperature. The pad has a 10W and 7.5W power output capacity for phones that support fast charging, and 5W for standard Qi-enabled devices.
The middle charging spot dials down to 2.5W, making it ideal for powering select Samsung watches and earbuds. It also works with AirPods' wireless charging case. A non-slip rubber base ensures the charger and phone stay in place throughout. The pad is compatible with wireless charging cases up to 4mm thick.
Pros:
- No annoying indicators
- Anti-slip design
- Intelligent cooling fan
Cons:
- Not compatible with Apple Watches
Source: Amazon
With a power output of up to 10W, the Ruishion Wireless Charging Pad is the fastest way to power your iOS and Android devices. The pad has three wireless charging stations and can comfortably support the 2.5W charging in Apple Watch Series 1 to 3, 5W-7.5W in iPhones, and 10W in Android devices.
Fast charging three devices simultaneously can cause any device to overheat. To counter this, the Ruishion pad has an advanced over-power protection system to guard your devices against overheating, over-charging, and short-circuiting. The pad is also compatible with wireless charging cases up to 4mm thick.
Pros:
- Fastest way to power Qi-enabled devices
- It automatically turns off once overheating is detected
- Powered by a USB cable
- Has a porous back for efficient cooling
Cons:
- Not compatible with AirPods
Charging all the devices
Wireless charging continues to evolve, and these best triple wireless charging pads will make charging multiple Qi-enabled devices a walk in the park. Besides, they will help you eliminate wire clutter. Keep in mind that, although any of these chargers will work fine with MagSafe-enabled iPhones, you can look at other multi-device chargers with more MagSafe compatibility.
The ultra-thin ZealSound Wireless Charging Pad remains our top pick. This stylish pad has a nice leather finish, and it's built with an intelligent temperature control system that prevents overheating and short-circuiting. It is compatible with a range of Qi-enabled devices and charging cases. With a power output of 5W, the pad is not the fastest wireless charger, but the 5W power output will prolong your battery life. Keep in mind that charging cases thicker than 4mm, and the presence of magnets and metallic objects will hinder most wireless chargers' performance. Otherwise, just lay your device down to power it up.
Grace Monene is an avid Tech Writer. If she is not reading, she is reviewing or testing new technology. She also probably tweets way too much.
Jaclyn Kilani is a content writer at iMore. She's a longtime Apple addict with a flair for creating (written works, design, photos; you name it!) on her devices. When she's not churning out new things, Jaclyn loves exploring the world, playing with her children, and good old-fashioned baking. You can read more about her expat lifestyle at MorningPapaya.com.
Top off your AirPods Pro with these fantastic wireless chargers
Want a super convenient and easy way to charge up your AirPods Pro? You'll want a wireless charger — here are our top picks.
Make your wallet unlosable with a specialized AirTag wallet
Do you have a habit of leaving your wallet inside coffee shops and Ubers? Or have you had a traumatic stolen wallet experience? If so, an AirTag wallet may just be what you need.
Want to use your USB devices with your new MacBook Air? Get one of these!
Use your USB microphone, flash drive, or even charge your older devices with these USB-C adapters.
