iPhone 3.0 Still Causing Wi-Fi Problems?
Back when iPhone 3.0 launched, we heard Wi-Fi was giving problems to some -- primarily iPod touch -- users. Various network resets or OS restores seem to have quieted that down, but now TUAW is reporting that the newly launched iPhone 3GS might be suffering Wi-Fi troubles as well:
Users note that signal strength can fluctuate between one and full bars even when standing right next to the router or when a computer nearby shows a constant signal. This goes along with a commensurate reduction in speed.
Neither Jeremy nor I have been experiencing this, but if you have, let us know in the comments, along with what type of router you're running, and what kind of speed/connection quality you're getting (or not getting, more precisely).
(Wether this is, in fact, a widespread problem and one corrected by iPhone 3.1 we don't yet).
There are 291 comments. Add yours.
My 3g runs fine on WiFi, but my new 3GS is MUCH slower...about half of the 3g when side by side. I get about 650 Kbps on a 3 Mb connection.
...and I am running OS 3.1 beta. I didnt see an improvement from 3.0 to 3.1.
I use an airport extreme, I up graded to a 3gs and gave my 3g to my wife. On the 3gs my wifi fluctuates from the dot to full bars, when the 3g consistently has a full signal strength along with my MacBook pro. I have done rests, configurations and everything else know to do, to know avail. I never had signal problems with the 3g but with the 3gs am lucky if I can get a full signal.
I have a netgear wireless n router. With my iPhone 3G the conneftion drops constantly, bars fluctuate and in most cases i cant connect. Before 3.0 i had no problems with wifi. Speed is also down
When I put 3.0 beta on my 3G I was getting a better signal and seeing a lot more hot spots when sitting right next to my girlfriend on the same 3G but 2.2.1. I also haven't noticed anything weird with my wifi on 3GS.
Just this weekend i noticed i wasnt connecting to my WIFI from my iphone 3g (running 3.0) i thought it was my router because it used to cut out alot but then my gf (who also has a 3g running 3.0) said hers was working perfectly fine. My wifi doesnt work AT ALL on my phone now (yes ive tried resetting the network settings, restoring, restoring from non back up) still doesnt work. I was actually going to go to apple today unless anyone has a fix?
When I say my WIFI doesnt work, it searches for networks and it cant find any at all when it used to come up with 2 or 3. Even in a mall it doesnt show anything.(and the mall usually has about 5 or 6 hot spots)
My 3GS has recently started forgetting my home WiFi connection. It's pretty annoying. I haven't noticed a speed slow down though, but I have noticed the reception jumping from 1 to full, which usually precedes the former issue.
Been noticing the WiFi bars bouncing up and down a lot at home, even when I have a strong signal from the Router.
Phone: iPhone 3GS with 3.0 (obviously)
Router: Airport Extreme 802.11n w/ USB Printer attached
I'm 15 feet away from the router and I see signal strength bouncing around. However, for the most part it appears to be working. I've mostly ignored it, but all the reports have made me wonder.
I've experienced this problem since updated my second generation iPod Touch. It's very strange. I'll post my router information when I get home.
I have a 3g, and I've noticed in the last couple of weeks that wifi is really slow or doesn't work for me AT ALL. I have a Netgear router at home, and I have no trouble with my computer on it, but I often have trouble loading pages when I use the wireless network at my office. Sometimes I end up just turning wifi off altogether.
I have an original 2G iPhone and have never had any wifi issues until OS 3.0...since then have had daily wifi issues. Unable to connect to network, no wifi signal even when next to Airport Extreme, unable to find wifi network, etc...everything as noted in the other comments.
I am running a full Apple setup here and have never had any previous problems. Please get it together Apple...that HTC Hero is starting to look pretty good.
This could possibly explain what I have experienced:
I like to listen to NPR in the morning. I use the Public Radio Tuner. If I use the wifi, it randomly drops the stream and reconnects, 10 feet from the router. But if I use the 3g modem, it never has to re-buffer. I think there is something to this. Heat?
I can atest to loss of wifi strength of on my 3G on 3.0 It's the sheer fickleness of the signal strength that bothers me.
I do not understand why they would muck around with end users stability if they hadn't shown consistant improvement on a high volume of test devices. Makes me wonder if Apple sprang for more than one test device. Even a small number of users suffering from this would imply that things should have been left alone for the time being.
Huh, I just thought my wireless router was having issues. For some reason I didn't equate it to this. I used to have full wireless anywhere in my house but lately the network doesn't even show up 75% of the time now. When I do connect it fluctuates constantly between 1 and full bars.
Guess it's another thing to add to the bug list. I had just been talking about the massive lag that came along with the 3.0 update yesterday.
My Netgear router is behind my couch where I set and sometimes I get 1 bar and sometimes it's full.
I have also noticed that sometimes it find my wireless in a few seconds other times it seems to take FOREVER!
Yeah, I've got exactly the same kinda issue. I've got a 3g with a connection to a time machine network (@ 3.5mb), I could be in the room right next to it and the damn thing will drop from 3 bars to 2! To be honest I think that the whole router range by apple are of a very low standard. Even on my MacBook pro the latency is absolutely appalling. Not sure if it's the software or just really bad hardware, one things for sure apple really need to sort this out.
I have netgear wireless 624 and iphone wifi goes down continuously and broadband speed is less too happens on both 2g and 3g phones
Where did he get the DSL Reports speed app? I can;t find it anywhere on the app store. I can find the Speedtest.net app though.
No problems here:
iPhone 3G
Airport Wireless Router (N)
Linksys Access Point
Optimum Online Boost (30MB/5MB)
Very fast performance. No signal issues.
I have a Dell wireless router. I never had problems with wifi until I upgraded my 3G to 3.0 and bought the 3GS. The connection with my 3GS now is highly unstable, regardless of where I am in relation to the router, etc. The connection drops constantly, bars fluctuate and in some cases I cant connect. Sometimes the phone can't even recognize that there is a wireless signal! This is definitely a 3.0/3GS problem.
I as well am having 3G S WiFi problems. Oddly, my 3G signal alone is amazing compared to my WiFi home network. My iPhone 2G loads speeds faster than my iPhone 3G S. I haven't tried connecting to any other networks. I'm hoping it's not a hardware issue because I still love the 3G S.
Yes I have this problem!!!! I can be right next to my router with full bars and next thing I know it's asking me for my wifi password again! It's starting to drive me crazy. Seems like if I cancel the login it still connects... iPhone 3GS with a Linksys WRT300N router.
Yup, same problem as others. With my older iPhone 3G I would get 2-3 "bars" wifi from my room. Now with the 3GS, I get 1-2, if I'm lucky. Some times I don't get any signal at all.
I also experience wide fluctuation with wifi signal strength using my airport extreme. It seems very random. It disappears and just as suddenly reappears.
I have been having problems connecting and staying connected on my new iPhone 3GS and places where I have full bars on my iPod touch v 2.2.1 and MacBook I have had to forget the network on my iPhone and reset the network all together.
My iPhone 3Gs shows full bars when connected to the wifi but when I open up safari and go to a site it never loads, it's like using an itouch without wifi...you can't view a page...no network
I am getting same problems ,3gs ,bt home hub 2.0
Both mine and my wife's G3's take about 10-30 seconds to connect to WI-FI every time they go to sleep. I didn't think anything about it till I went to a friends house and it was constant? Anyone know how to fix this?
When I am standing about 5 feet away from the router, I can get signal between 1 and 3 bars. Sometimes I also have trouble scanning for wifi networks at all. I switched on the signal strength meter in stead of the three bar and the readings were all over the place, too. It's not just the bar misreading. I am also having very annoying troubles with Bluetooth pairing. My Phone just exits and enters pairing mode, ignores pairing requests, and won't connect to anything else. I took me half an hour to pair with my computer.
I've noticed the indicator bouncing around when I'm close to my router as well. Also, I was in a hotel when 3.0 first came out and I couldn't pick up any Wifi networks even though I could see 4 different hotel networks on my PC.
I'm having the same issues with wifi as everyone else. I upgraded from 2g to the 3gs running OS 3.0 on both. I never had the problem until 3.0 upgrade.
I havent been able to see or connect to ANY wifi networks, even public ones, I tried the ohare network and it wouldnt show up, anyone have a fix for this?
I had this problem on 3gs and 3g running 3.0.
apple support escalated it and recommend new hardware. New 3gs yesterday. No change.
Netgear wireless router. Issue is with all routers.
Very frustrating. No help from apple.
Google "strange iPhone wifi" and you'll see apple support forum thread on this. Long list getting longer!
Yours in misery
R
I have a touch which I recently upgraded to 3.0 and just bought a 3GS. I find that I can one in each of my hands 15 feet from the router and one can have full bars and the other a dot. 20 seconds later it reverses.
Definitely something wrong with the Wifi connection on 3.0. I never had an iPhone before but had the touch for quite a while and never saw it fluctuate so much before the 3.0 upgrade.
And regular phone reception is now worse.
Lucky me!
Yeah, I've pretty much given up on using Keynote Remote while teaching class. If would be nice if Keynote/Remote also supported BT.
I fluctuate between 1 and full bars all the time. Most of the time it's fine and full but then all of the sudden it'll drop to 1 bar and then slowly go back to full bars, all in about 15 seconds... sometimes a bit longer. The whole time I can be standing still next to the router. I'm on a 3GS.
I find it strange that they would mess with Wifi in the software for any reason. If it's not broken, don't fix it. Maybe it's a power save feature gone haywire. . .
I've always been able to stand next to my router and not always have full bars.
I have the netgear n router and when i got my 3gs i had all the same annoying issues. I have now SOLVED it. Go to this link and put on the latest firmware:
http://kb.netgear.com/app/products/model/a_id/2331
Instantly solved all issues and now works better than my 3g ever did.
Hmm, well my Wifi connectivity is fine and doesn't appear to go up and down. However, since the 3.0 update the speed doesn't appear to be as good. Things load much faster than 3G still, but I think they were faster. Also using the speedtest.net app and the same testing server on my laptop my iPhone 3G no longer gets anywhere near the speeds it used too. Looking at my history in the app here is what it reports.
Average speed before 3.0 (down/up)
9Mbps/3Mbps
Average speed after 3.0
3.5Mbps/2Mbps
Average speed testing with laptop (speedtest.net, same testing server as iPhone 3G)
15Mbps/5Mbps
I have Comcast cable internet and a Netgear router.
Oh yea, router is set to 'g' only devices.
Same problems here with 3g since I updated to 3.0( no problems before) and with my new 3gs, wifi drops constantly on both, poor reception and password incorrect prompts randomly popping up, have tried resets and restore with both and every fix I could find with no avail!
Try updating your routers firmware.
I have some issues with wifi on my 3GS. Like an earlier comment, when I was streaming Public Radio Tuner it would drop every few minutes and then reconnect (at which point I would have to go through the intro recording about who sponsors the programming). But I've not paid attention fluctuations in the signal strength.
One thing that annoys me is the 3G service. I switched from EDGE to 3G earlier today. It connected to 3G, full strength (the tower is across the street). A couple minutes later it was dropped completely from the network. I didn't move the phone, it was just sitting on my desk. Wouldn't reconnect until I turned off 3G and back on. Then it was fine. Is this typical of AT&T 3G service? I never had an iPhone 3G so I only had EDGE to work with on my old iPhone classic.
I'm experiencing the same issue as K1. Where sometimes my 3GS will drop my home WiFi connection while my laptop and GF are sitting right next to me and they all work. Also sometimes I have to reenter the password. Since this on my home network and at work. Even when I use the correct password it'll say it's wrong and I have to keep trying and finally it'll connect. Doesn't happen frequently enough to replicate the issue to find out why exactly it is happening.
One thing I did notice, if I go into settings and go to Flight mode on and then off, WiFi will then connect again with no problem.
I had an original iPhone that never had any problems connecting and staying connects to my Linksys WRTGL router. My new 3GS on the other hand often drops to 1 "dot" on the connection icon and also loses thenconnection completely from time to time. My router is 4.5 feet away.
I decided to try this at work with 2 of my co-workers who have a 3GS and a 3G.
The 3GS and 3G both on 3.0 performed nearly identically on both secured and unsecured networks in terms of up, down and latency speeds.
I'm not saying some people don't have an issue, just that my test showed something quite different than the video.
Using a 3g phone with 3.0 and the original airport router here. WiFi distance has definitely been compromised. I used to connect in my back yard at full strength, a surprisIngly long distance from the router at well over fifty feet. Now I get wild fluctuation, as little as one bar from twenty feet. My MacBook Pro is not affected; it's clearly a problem with 3.0.
I haven't noticed speed issues, but I have had problems with my wireless network being forgotten and having to frequently reenter the password since upgrading to 3.0. I had somewhat similar problems way back on 2.0, but haven't had any issues since 2.1 was released. I'm using a Belkin router and an Actiontec router.
Looks like a US thing my 3gs is super fast in the uk and the wifi is full and only drops I am about 20 m away. I use a very old and crap bt router so nothing that would help the phone out?????
Same issues here with erratic home wifi connection with my new iphone 3GS . Whats weird is that my old 3G with 3.0 has a perfect signal all over the apt as does my ipod touch, but the 3GS drops down to 1 bar and suffers major speed issues (i turn wifi off as 3G signal is faster with utube etc. !!!)
So after all the troubleshooting (reset network settings , restore 3GS etc.) apple replaced with a new 3GS and I still have the same problem !!!
I have a linksky WRT150N router btw and it kills me that my 1st gen touch aswell as my old 3G get perfect wifi while the 3GS struggles ,,,very frustrating
I have had this issue since i first got an iphone 3g on os 2.0. I currently have a 3GS and am experiencing same issue. my router is a dlink dual band wireless n router. neither apple or dlink have solution. my home signal fluctuates from 1 bar to full signal.
i have been complaining about this since day one.
Same issue here from day one. Also on my 3GS cell reception is awful. I always used to have full power at my house, now I'm lucky if I have 1 or 2 bars.
I had this problem with my 3GS...I actually ended up returning it because of it. WiFi signal would fluctuate wildly, and sometimes drop the connection entirely. Interestingly enough, I have NO such problems with my 3G on OS 3.0.
I am using Asus routers running DD-WRT (build 12360).
Posted this problem on your forums days ago: http://forum.theiphoneblog.com/iphone-forum/173475-iphone-3gs-bugs-issue...
iPhone 2G user here..
My WiFi was working perfectly while in 2.2.1 version (and all the previous versions) but 3 days after I installed 3.0 it started acting weird.
Now it doesnt find any network even if I stand next to my router (Speedtouch 780)
Downgrading the baseband and Firmware to 1.1.4 fixes the problem but upgrading to 3.0 kills WiFi again...
hopefully apple will fix it in the next upgrade!
My 3g has had this wifi problem since i upgraded to 3.0. It is very sloooww and sometimes disconnects. Even when standing riGht by the router. Its so annoying!
3gs seems faster at everything to me than 3g is
Wifi not working at all on 3GS. I had a 3G and it stopped working as well once I upgraded. Now it doesn't even allow me to join a network. I have a linksys router.
i am having the exact same problems as freiteez... my phone will not connect to wifi even when right beside the modem... the weird thing is that my old 2g with 3.0 is working fine with the wifi.
sorry i forgot to mention that my phone is a 3g and my modem is a linksys wireless n..
I have an iphone 3g... Since upgrading to 3.0 on my iphone the remote application seems to drop connection about every 10 seconds and eventually comes back but it takes 30 seconds or more.
With iphone OS 2.2.1 my connection was solid and didn't drop hardly ever.
All I have at home at the moment is my MBP (use a USB broadband wifi modem) and my iphone (use 3g for internet at home) and so I use my MBP and create an adhoc network on airport and connect my iphone to that so I can control itunes using remote.
It has never been this unstable.
I have also had the new remote update (1.3) for a few days now and it still doesn't make it better.
After connecting the iphone wifi to my network and opening remote it takes a while to connect to the lib and after a short time it drops out shows this message...
"Cannot connect to a local network.... you must connect to a wifi network to control itunes or apple tv"
then if i wait it will reconnect and then drop out again for as long as i can be bothered to look at it.... It doesn't make a difference how far away from the computer i am either... if its 5 inches away it doesn't change anything.
The adhoc network on my MBP seems to be much more stable for the iphone 3g if I share my internet through the airport. Weird
How long was 3.0 in beta? That's the funny part.
I had the same issue after upgrading to the iPhone 3gs. I previously had the iPhone 3g. My wifi would constantly drop out. After a network reset things would work fine but when the phone goes into sleep mode the wifi fails to reconnect. I got the phone exchanged for a brand new one but it still had the same issue. Instead of doing steps separately to figure out the problem I just upgraded my routers firmware and then set the wireless mode to b/g only. I have a linksys wrt310n router. So either the n signal or the firmware was the problem. Ever since I made those changes the wifi on the iPhone 3gs works perfect!!!
I just got the 3gs and my wi-fi connection seems to connect for a split second after entering my password. However, I just gave my wife my old 2g and hers seems to connect just fine even after upgrading to 3.0. My wifi router is a AT&T 2WIRE.
I am also having the same problems. I just bought a 3gs as this is my first iPhone. I have noticed that my Wifi goes from full strength to no bars and I'm sitting right next to the router. I'm using a Linksys Cable Gateway router. I had the same problem at my friends house on his network and he is using a Linksys router too. It's not too often, but it is annoying.
Before 3.0 I would always have a constant signal in my office with no problems. After installing 3.0 signal fluctuates from full to one. Also the connection is not stable, constantly connects and disconnects when signal is weak. before 3.0 even with a weak signal my iphone would stay connected to the network.
My 3GS is having problem on my 802.11 N compatible router. When running on N/G/B (Auto mode), my iPhone will disconnect intermittently. When I stream music or videos on it, it will stop just few minutes after, never able to complete the whole thing. However, if I set my router to run on G only mode, then everything runs smoothly. It seems to me OS 3.0 has compatibility issue.
Ron Jeremy's wifi is slower on his 3gs than his old 3g also Ron's signal goes half to full limp while sitting on the can playing poker. Apple needs to fix this issue for Ron with 3.1, Ron's 3g speed is gobs faster than his wifi.....
I updated to 3.0 and my 3g is cr@p now. It will not find any any wifi networks and maps is usless as it cann't determine it's location. Iv'e made an appointment today for the Genius bar, so we'll see what they say.
I've noticed, particularly since 3.0, that my iPod touch has markedly slowed down over wifi connection. On several occasions normally stable programmes have frozen and been kicked to home screen
cheers all,
I found a solution that worked for me 100% (3G). Factory restore 3.0, activate with valid SIM. Do not (really do not) RESTORE BACKUPS. I have same wifi like 2.2.1
If you jailbreak/unlock use .072 only AFTER you have done the above.
Hope it helps!
Since i got my 3gs, i've had the same problems reported here. takes a long time to connect to wifi, low bars even when i stand right next to the router (netgear wireless g) overall bad performance.
My 3g was great with my linksys router. Anywhere in the house I had wifi. Once I downloaded 3.0 the only way I am on wifi is when I'm within 10 feet of so from the router.
Even my 3g signal strength is a bit iffy where before it wasn't too bad.
I keep beating myself up for downloaded the damn 3.0.
Anyone have a fix yet for the wifi problem?
I found that changing the channel number on my bthomehub 2 router solved the 3gs wi-fi problem.After two new iphones and a long time on the phone to apple ,not that they helped ,I had to root around the net to find info,hope this helps someone.
Purchased my 3GS on opening day. I was all excited about getting some sweet 3G performance. Back at the office my WiFi setup perfectly and same at home. (Linksys WRT600N on dd-wrt). Our CEO picked one up and is fighting tooth & nail to get the wireless going. Sometimes it forgets the SSID; sometimes it won't accept the PW; standing right at the Linksys getting signal-to-noise ratio half that of mine from a distance of 60+feet away. He gets the same performance from the exact same hardware at his house.
The Broadcom combo wifi chip in the 3gs sucks. Apple should have kept the Marvell chip to handle wifi.
My old 2g has this problem. I just basically use it as a touch, with bt off and in airplane mode. I like to use pandora and finetune, and dock it in my Bose soundock, but it won't keep a connection and sometimes won't connect. It had this problem before 3.0. My 3g so far hasn't had this issue. I use a linksts at work and actiontec at home. The symptom are pretty much the same as described by everyone else above.
I'm concerned...I downgraded back to 2.1.1. I'm waiting for them to fix the bug, but all of the apps are getting upgraded for 3.0, and I think that soon 2.1.1 will be obsolete. And I'm hearing that the 3.1 is not fixing this problem. This is a real hassle. Since I need my wi-fi to sync with FM Touch, which is the reason I have the Iphone, I'm worried that they won't acknowledge or fix this problem.
After upgrading my 3G to 3.0, wifi became flaky: connections become slow, freeze or drop. Indicated signal strength varies from one dot to full while near the router. I used to receive my home wireless 150 feet away from my house (WAP54G Linksys), now it is 50 feet at best. Auto-connect does sometimes not happen (my local attwifi @ starbucks) or only after a minute. Also noticed that entering BlueTooth discovery mode causes wifi to drop.
Hi i am having the same problem. We have 3 iPhones 2 3G and 1 3GS, Router i Belkin Pre N.. Its seems to only since 3.0 came out
Still got 3 solid bars on 3gs,after changing the wi-fi channel number on my router.Happy days
Same issue. Wavering bars while feet from the router. Net gear dual band. I often can go into settings and reconnect
My wifi problem is a little different. 3G works great. I can access any websites. But when connected to wifi, I can't access certain websites. Turn off wifi and bingo - I can get to them again. I can access those same websites through my wifi network using my laptop, so I'm pretty sure the issue is at the iphone level.
Yes I'm having the same problem. Only get 1 bar when connected to wifi. I sure hope they fixed this with next update.
Same issue here will not work
With my BT Home Hub 2.0 and Iphone 3G S - I was experiencing a low signal even standing next to the hub itself. I changed channel and within 10 seconds I had 3 bars. Great!
I am having the problems at work my 3g or 3gs will not connect so I thought we were having problems with the network at work. When I got home the same problems will not connect. Apple please help!!!!!!
I have an original I Phone and once I updated to 3.0 I immediately lost all wifi. It says I am connected but I get no bars and I can only function on edge. My outer is the 1terabite time capsule and my Macbook works fine off the router. This is a 3.0 issue.
I have lost my WIFI and 3G since I upgrade from 2.2.1 to 3.0 ( 20 days ago)...that´s is not compatible with normal iphone life...simple horrible have a iphone whitout Wifi/3G...I hope TIM Brasil change my phone soon..because I have tryed all receipts to solve the problem, but this is impossible...only one exit FW 3.1 !!!! At least, I hope!!!!
We've got two iPhones in our household both 3g
One doesn't recognise any wifi networks anymore :((
One changes between 1 and 5 bars
Tried with different routers but using the dualband aebs at the moment!
APPLE PLEASE FIX THIS MESS!!!!!!
I have a 3G and since the OS upgrade, cannot get WIFI to work. Have tried both a network reset and a full restore. No luck.
Emmett
My 3G 3.0 first started having problems with connecting to my home and work WiFi. Than since yesterday it does not even detect any wireless networks. Never had similar issues before 3.0 update.
I upgraded to 3.0 when it first became available (I have the original $600 phone - yeah, i know...sucker!).
Recently, my phone is not recognizing my network password. It recognizes that the network is there but I cannot log on. I have not changed any password settings on the router. Just doesn't seem to recognize it anymore.
Strange...
Had no problems with 3GS at first, then last week started degrading until WiFi was useless (only 1 bar no matter where). Tried ALL recommended fixes - nada. The store saw the problem & replaced the phone. STILL HAVE THE SAME ISSUE on the new one!
Software upgrade to 3.0 was working well for a while. Then suddenly, can't find any WiFi networks. WiFi finder in Settings won't find a public network I use at the office, nor my own WPA2 network at home. Tried resetting networks, and even wiping the phone completely.
After several attempts, am headed to Apple Store soon.
First gen iPhone updated to OS 3.0. Wifi takes forever to connect - under 2.0 it was almost instant. Signal strength varies somewhat. Used to be able to use netatalk to connect from my Mac. Can't anymore (though the fantastic cyberduck works).
My first gen iPhone was updated to OS 3.0 Now it either fails to recognize any Wifi signals, even when I'm standing next to the router and my laptop is registering full bars, or it recognizes it for a few seconds then looses it and can't refind it.
Same problem with my 3GS. Sitting 5 feet from the router (BT Home Hub 2.0) and 3GS is showing 1 bar. A restart seems to sort things, but only for a few minutes - then the problem's back.
My old 3G was fine - why have they messed with this? :o(
Same problem here. 3GS reception on both wifi and cell is HORRIBLE compared to my 3G. I never, ever dropped calls on my old phone, but the new one is doing it several times a day. Wifi in my home is awful (airport extreme base station) on the 3GS but not my wife's 3G.
It seems weird that such a basic problem would have escaped Apple's review process.
Still No solution. This is the First Apple product I have been disappointed with.
3GS on ASUS Wireless N router. My 3G I used for about 6 weeks and it was rock solid at top speeds (10MB). Anytime I was in my house, it worked perfect - never a single problem.
3GS - drops N constantly and 80% of the time I'm running off 3G instead of wireless. Signal strength varies - and it will drop me and keep asking for the password.
I have now turned off N on my router - and so far so good. Friends with 3GS and B/G routers have not had the same problem.
I suspect it's the 3GS and wireless N that results in issues.
must be a power saving issue....when my iphone 2G is plugged in i have full wi-fi in my room. as soon as i plug it out the bars bounce around for a while until the edge "E" symbol pops up. it can stuck on this for a few minutes then all of a sudden jump back to full wifi signal. strange!
My iPhone 3G will also NOT find ANY wi-fi networks. This happened after the last software update. The search spinner will appear for a split second and NO networks will show up. My laptop connects fine.
3G works flawless both before and after 3.0.
3GS very weak connection, lots of connection losses, even directly next to router antenna.
This is VERY frustrating.
I havnt been able to connect to the internet with my iphone 3g ever since i upgraded it to firmware 3.0. Please I need answers.
I also have been having Wi-Fi issues with my iPhone 3GS as of lately. Mail takes forever to load, or sometimes doesn't...the revolving circle above the iPhone just keeps on going. Also, YouTube has been impossible to use, just cannot load videos at all on Wi-Fi. I think it's time for Apple to address these problems with a new update.
Have the same problem everyone is talking about. Since the 3.1 "upgrade" the wifi ain't working good at all. Can't download the big apps anymore, bummer :( Leys go apple!
WIFI worked great with my 3G for months, then I upgraded to 3.0 and suddenly it's pretty much gone! I can occasionally trick it into connecting by constantly refreshing the network page in Settings. On the rare occasions that it notices our wifi network, it will connect (sometimes I have to re-enter the password) then within a few minutes it's back to 3G. This is while sitting right next to my laptop that shows full 4 or 5 bar signal strength. It's driving me nuts!!
New iphone 3GS user here (my first apple product in 20+ years!). Experiencing same unstable wifi signal sitting right next to a linksys wireless G router. Laptop signal does not vary and is quite strong, but iphone usually shows 1 bar only, and sometimes disconnects totally. Also have rare 3G signal (usually shows Edge) while my old Sony Erickson phone always showed full or near full signal. Very frustrating after this investment.
..forgot to add, if I go into Airplane mode while having wifi trouble, and then back to normal, the signal shows full strength again, but weakens again upon use, after a few minutes. GRRR...
I have a Factory unlocked iPhone 3G. Absolutely no issues proir to upgradgint to OS 3.0.
Now the phone just sucks, wifi wont connect at all. Will not even detect the routers in the area! Used to find my router and my next door neighbours router earlier.
Anyone know how to restore the baseband of the modem and the software back to 2.0.1?
I have not had problems with Wifi. In fact the speeds are about the same as my MacBook Pro. I have had problems with the 3G dropping calls after the 3.0 software was installed on my old 3G and of course my new 3GS. I rarely had calls drop when I was home until the 3.0 software. Now it happens about 50% or more of the time.
BTW, I have a Linksys N router.
I'm having the same issue with my Belkin n router. Annoying since the update cost 8 quid!
I have the original iPhone 3G. I downloaded the 3.0 software update when it was first released, and had no wifi issues for about month afterwards. However, iPhone will no longer connect to wifi for the past week, 'Unable to join the network'. I've tried all the iPhone and wifi resets and have had no such luck.
What is happening!?! Please can anyone help me?
my iphone 2g wifi has stopped working.. i have tried everything, restore, dfu restore, upgrade to new 3.0... what the fuckkkkk. any help?
I have a 3GS and the last couple days it would connect to my home network but give me an error saying there was no server. After reading the posts I went out and updated my routers firmware. Now it works fine. Thanks!
End reslut 3gs another apple crapy product I am returning this POS back to them!
I have had the same problem as everyone here, is there a resolution please? I came to this website looking for a fix but it is just a massive list of people experiencing the same! Does anyone have news on how to overcome this?
Since I installed 3.0 last week on my touch 2G I gor WiFi problems: after waking up, in 50% of the cases, the WiFi connection does not work. Either I have to wait a few minutes or I have to manully renew the lease. And it's slower than before: network, launch of apps ....
Not a real improvememt ....
I upgraded my iPod touch 2nd gen to 3.0 & when I did it cannot hold a strong wifi signal even though very close to the router, it did work before but not now. Myself & my gf both bought the iPhone 3gs & are having the same issues with wifi connection. I have done the steps apple recommened but still nothing.. It connects full strength until I start safari, email, or anything that needs the Internet. Please fix this in 3.1 apple!!
I got the new 3GS after having had the 2g iphone since its release. I never had a single problem with my 2g and ever since getting the 3gs i cannot ever connect to wifi anywhere. I personally think the problem is related partly to 3GS hardware becoming to hot considering i read a report online saying that a man put his 3GS which wifi was not connecting at all in the freezer for 5-10 minutes. When he took it out he claims the wifi worked perfect until it warmed back up. This could end up being a major blow to apple if the new phone they just sold 100's of thousands of has faulty hardware because they are definitely liable.
I have an Airport Extreme router and two Airport Express units in my apartment. My two MacBooks and Linux box get perfect 100% signal, as does my iPod Touch running 3.0. My 3G iPhone, however, used to work fine on my network but now will not connect (started shortly after 3.0 upgrade), and actually never sees any WiFi networks anymore. I wondered if that module was affected by dropping the phone but after seeing all these posts I think it a soft/firmware problem. Apple please help us!!!
Fix: Change from DHCP to fixed IP address on your iPhone. Also change channel from Auto to 11 on your router. No wifi issues anymore. Never drops now and I have full strength all the time now!
I just upgraded from a 2G to 3GS today. My 2G has always been slower than it should be on my home WiFi: 2M down/420k up. My MacBookPro gets 6M down/430k up (my native DSL speed). My router is a Dlink 615 set for 802.11N (switching to G or B results in slightly faster down link speeds). I visit two other locations using LinkSys 802.11G routers where my 2G gets 6M download speeds. Today when I picked up my 3GS I found that the 3GS got 10M down/ 10M up in the Apple store. At home, my 3GS is getting the same 2M/420k speeds as my 2G. I'm suspicious that there is a critical configuration difference between the router configurations at locations where I get good speed and those where I get bad speed. I've also noticed that high latency routes on the internet will get significantly slower speeds both the 2G and 3GS iphones using WiFi. My tests with Atlanta as an end point run at a fairly steady 2M down but the same test with a Fort Lauderdale end point with much higher latency will show an erratic speed of 500 to 600k down. The same tests on my MacBook Pro show 6M down for Atlanta (low latency) and 5M down for Fort Lauderdale. I use the SpeedTest.net app
Ever since I've started using the iphone 3gs, I have noticed that Wifi has been a pain. The phone keeps connecting to wifi then cuts off and goes to 3g. Once I restart the phone, the wifi connection comes back but then disconnects from wifi and I get this pop up asking me to enter my wifi password. I'm not sure if this a 3gs issue or 3.0. Anyone else experiencing this let me know if you know of a fix to this. Thanks
Me too. Frequent signal strength fluctuations and drops. Sometimes reconnects fast and without prompt, other times asks me to choose my own network. I have to reselect my network maybe 3-4 times per day. Frackin‘ ridiculous.
Turning off Bluetooth seemed to work for me. It looks like Bluetooth is interferring with wifi.
if you having wifi problems a network reset will fix the problemhttp://iphon3n3wz.blogspot.com
Jose, I tried the resetting of network method and it doesn't work. It only works properly if I turn my bluetooth off. Then it works perfect.
Well, I think I have isolated the 3.0 problem. It is with 802.11g If I lock my router to B only, I see full signal, no dropouts. If I set it to b/g or G only, it drops all the time.
What pisses me off most is that we had EXACTLY the same crappy issue when 10.5 came out first on the Mac. And it was a problem for thousands of users. It took Apple ages to fix it and now I'm getting the same damn nightmare on my iPod touch again. This is just lame.
I just updated my 3G software to 3.0, and wireless never connects automatically anymore. It is a much weaker signal after I select a connection manually. Why should iPhone owners have to become network experts to fix this problem caused by a software update. This is a big enough issue for me to switch to a Blackberry!
Same Issue. Tried restoring, blowing out network settings, fiddling with my router. I must have tried every viable solution from the Apple message boards. My phone is less than 2 weeks old! Wifi worked fine for a few days after the 3.0 upgrade...then it started get flaky. Now I can't see any WIFI networks regardless of my proximity and router security and SSID broadcast settings. Even checking the "About" tab in the settings indicates that I have a WIFI MAC address so no dice on that one. This is absolutely unacceptable for a "modern" smartphone. Should have gone with the Google phone instead. If anyone has the same symptoms and has a viable solution please post it ASAP. This is most definitely an Apple problem. Don't waste your time messing around with your router.
So, here's something interesting. Linksys WRT54G v4, running latest firmware. Had it transmitting mixed signal of both B- and G-. If I happened to power cycle my new iPhone 3G S, as soon as it would hop back onto the network, it would kill the whole network, router connection, everything. All computers dropped on network, and only way to get it back up was to restart the router. I switched it to G- only and problem seems to be resolved. I have no idea, then again, it's been a long day in the tech world, so not really thinking. Cheers!
I think I found the answer though. Turn off your B. Only G. Maybe? Again. Long day.
Nevermind. Sorry, y'all. So, I can't reboot my phone, otherwise it completely jacks my wireless network. I have to unplug it. Resetting it doesn't even do anything. Whatever. I have a Mac, Dell, Dell, two Airport Express stations, one iPhone 3GS with Remote that I use to control the speakers. Any help would be appreciated. Thanks!
I have the same problem. With 3.0 it didn't even connected to wi-fi... but it could see the wi-fi network. Today I updated to 3.1 and it miraculous connected. Lasted like 2 minutes. Started to change between 1 and 3 bars and disconnected. HELP!!!
I have notice that my wireless N Netgear router doesn't give my iPhone, MacBook Pro, my girl's Dell Netbook or any other WiFi device a full signal. However, Wireless G router on my girlfriend's house runs both of our iPhone 3Gs and other WiFi devices perfectly.
I think wireless G is the way to go for me and mine.
My 3.0 worked for 2 weeks, since yesterday - doesnt show any wifi networks. even with more advanced apps like wifiTrack etc.
This iPhone is new - apple replaced it, and now it has this problem.
Im scared to death that i have to replace it again. I dont live in the us and i have to send it there again.
do u think its hardware?
before the problem rose i used the GPS for about an hour - and the iPhone did get a little warm (id say 40-45 celsuis), do u think it melted?
i tried the freezer thing, it worked for less than a second and doesnt work anymore.
plz calm me down!
My ATT Uverse works just fine...perhaps withsome reduced signal. HOWEVER, since 3.0 was released I cannot connect to any Starbucks wifi (FOUR DIFFERENT LOCATIONS!). Call to iPhone support was that they had received a number of calls. 3.01 was all security related updates, but tried anyway. Still no connectivity to bucks wifi. It shows connected in the network settings, but the connecting wheel never stops.
we have 2 iphones - upgraded one of our phones to 3.0 - unable to see our wireless network at home. phone 2 has old o/s 2.2.1 - wireless network is up and running. same exact phones/network - version 3.0 creates a screen as if "wi-fi" is not at option at all.
I was pretty happy for 6 months, I bought a wifi router just for the Iphone! I worked like a champ until 3.0! I noticed right away the wifi was acting weird and now it see's the connection just fine until I go to use it then after about 15 second delay it switches to 3g! I'm pissed off at apple! I only updated because I want mms, I also love the way AT&T won't let us use it! This will be my last apple product!
Hi Well I dont know why but my Ipod Touch 3.0 just recently lost its connection with my wi-fi
I can use the internet with computers and stuff like that but it doesnt work with my ipod
i can't seem to connect it back with my Wi-Fi
even if i type in the password it says"Unable to Connect With "NAME HERE"."
Update: I was getting ready to back up my phone for an exchange when I decided to try to connect to wifi one more time after 2 weeks without! I unplugged my router, then reset the network on the Iphone, phone restarts, then after about 2 min I plugged the router back in and everything works like it did before! Try it! I did multiple speed tests it works good again! I hope it lasts! So far connected solid for 2 hrs!
Thanks J.S.!
I have been experiencing the same problems on my iTouch since 3.0,a nd your little trick just worked! I hope it sticks, but for now, it seems to be working. Thanks!
I have a 3GS and my wife has a 3G.
First noticed issues with my linksys 54g ( old first gen) and the router had been acting up in general so I tried a linksys wrt610n and my speed seems better.
My biggest issue is connecting to the iTunes store or app store by the iPhone. Both will give a cannot connect to store message randomly over wifi. If I turn off wifi and try again it's ok ( for a while)
Very weird. Hope 3.1 helps
I have an iPhone 3G 16 GB that has been working fine since the OS 3.0 update until now. All of a sudden I lost the Wi-Fi connection and I can't get it back. I have tried everything! The iPhone shows a Wi-Fi MAC-adress under Settings > General > About but it can't find any networks? When searching for networks it spins for a second and then says that it can't find any networks. I've tried to enter the network manually without luck. My network is unprotected with SSID broadcast turned on! Bluetooth works fine and doesn't seem to have any impact on the problem. I've never experienced any issues before 3.0 A complete factory restore doesn't solve the problem either : (
I HAVE SOLVED THE PROBLEM!!
settings>Wifi then on your home wifi(connection) tap the blue bottum on the right, then tap DNS and enter your routers IP.. find your router/modem IP on
PC Start>network then right click on your router>properties networkdevice just type the IP on Your Iphone/ipod touch
This worked for me:)!
My 3g connected on my home wifi the day I brought it home, but since that day I have not been able to get connected to my home wireless router. I've even tried to join it direct by inputting Network name and PW....Still nothing...
Am I missing something with this, or ???? Thanks for any ideas.
gabi got it right!! Full power Wi-Fi from anywhere in my house, and with my cordless phones and bluetooth and microwave all functioning at the sam time. Bravo!
I have first gen phone and wireless always worked at home. It won't even find my router anymore. Laptop connects to my router fine with a strong signal.
Switching of Bluetooth definitely fixes the problem, but of course then no Bluetooth. Gabi's sounds better, but I really can't follow the instructions "home wifi(connection) tap the blue bottum on the right" huh? where? - it's not at all clear where all these things are.
Switching of Bluetooth doesn't do anything - at least not for me. I never had it on and I do have most of the issues...
Have a 3GS and a 3G. Both devices side by side:
3G is faster (regarding throuput) more stable, is able to stream videos when 3GS won't and in some places the 3GS looses the wifi (or doesn't find it) where the 3G does...
PS: BOTH devices run OS3.0
I have a 32gb 3gs. I have a belkin n1 router with 15 Meg Internet. Wifi takes forever to load any video bit places like starbucks I connect fine and fast.
Same problem with the 3Gs running 3.01 as everyone else. My router is a linksys wireless G 2.4GHz. Just using 3G until there's a fix. Please make it happen Apple!!!
Same problem as everyone else here with my Iphone 3gs. My router is a speedstream. Wifi flucates. My son's ipod touch (not updated) has a full strong signal. Help!
I have an IPHONE 3G and an IPHONE 3GS. My wireless router is a Linksys WGC200. The router has now probles commnunicating with devises connected using ethernet. but when MY 3G phone uses the wirelessnetwork, the phone losses the connection, and the router end up in limbo, causing a router reset. I replaced the router. It still happend, so I now suspect the phone is the issue. Aftyer reading the posts, I see it is the phone!!! Any feedback from apple?
I had the same problem on iPhone 3GS, 3.0 Jailbroken. Someone in a forum suggested not to use push email or set it to 15 min. I shut it off, restarted the phone and now it's fine. For how long though....??
I've been having the same connection problems with my 3g iPhone and went into apple they said they no of no problem. Then went into 02 the same answer but they changed my network data settings then somebody else came in while I was there with the same problem. My iPhone is still not working properly it is better but then again it could not get much worst.
I don't if this applies to the 3G model as well but I have discovered what appears to be a very fundamental design flaw. Ever since I bought the 3GS I noticed that the signal strength fluctuated, frequently fluctuating between a full 5 bars and a 1 bar or nothing. I tried to find the answer to this problem on various forums with some weird explanations like attaching a USB cable or a scotch tape to the sim. Nothing I tried improved this. I noticed that it seems to drop just when you made a call and recovered immediately after the call.
This made me wonder if it had anything to do with how the phone was being held. Some users were saying that two identical units would report different signal strengths at the same location in the same network.
Anyway after a lot of experimenting I discovered that the iPhone 3GS appears to be extremely sensitive to being held on the lower 1/3rd part of the handset. Holding the phone in the top half recovers a full signal within a few seconds (15/20 secs)!!!!
You can try this yourself. Putting the phone down on the table or picking it ensuring the bottom half remains uncovered seems to work. Covering the bottom half starts to drop the signal.
The design flaw is that the receiving antenna should be placed at the top of the phone which is least likely to be covered when held. Either way it's a flaw that Apple should recognize and fix. Other handhelds don't seem to suffer from this characteristic.
I have the original iphone, and also have lost wi-fi. I tried gabi's solution (aug 12 post) and while my phone does not show the wi-fi bars, it is acting as if it has wi-fi. For example, it used to be very difficult or impossible for me to download youtube videos over the EDGE system, but now I have no problem at all. Can someone explain this. I am on wi-fi or not?
After spending all day with a similar problem “disconnecting wifi on my iphone 3G OS 3.0” I think I have a solution. Go to settings, wifi and delete (forget) all other wifi signals that may be interfering with your prefer wifi signal. It worked for me… good luck.
I was having similar problems with my Time capsule wifi on my iphone 3G since upgrading to 3.0. I have a 20mb cable solid download speed and my iphone always ranged 3-5mb download however after 3.0 I only reached 6-200 kb on wifi after the upgrade while on 3G with wifi off it was getting 2Mb download.
My solution came from within the airport settings in the time capsule.
In AIRPORT WIRELESS WIRELESS OPTIONS I ticked "Use interference robustness"
I can only deduce that the 3.0 firmware is not as good at warding off those neighbouring networks that are growing day by day(I have 10 around me) not to mention bluetooth DECT phones etc.
Hello All,
I have researching this issue for a while; my wifi reception and my gps go together; when I first got my 3GS it worked fine; few days later the GPS reception went bad and simultaneously the wifi reception. I get wifi signal if I am less tan 10 feet away from my Apple router. I tried all kind of resets, reconfiguration, even firmware restore; nothing helped. When I gave up and forgot about it, the second day it worked like a charm; I got the wifi back and the GPS back.
Now that I have been happy for another week using GPS and wifi, I woke up yesterday with no wifi; I jumped ou to check the GPS, the same problem is back; GPS locates me based on GSM antena triangulation with an error of few miles.
My guess is the following:
If it is a hardware issue, then the more I use my iphone wifi the worst it gets as I noticed the problem after a good day using wifi; I believe the GPS uses the same antenna and that one is getting tired.
If it was a software issue, a full restore of the phone should have resolved the problem, or why the hell GPS stops when wifi stops?
My post is not helping is finding a solution, but at least it gives another perspective of the problem.
Anyone out there is having simultaneous issues with wifi and GPS?
Hi Pacopass, I agree. I was using my iphone 3g extensively before the i lost the ability to connect to wifi networks and get a GPS track on maps.
I am using linksys wireless G 2.4GHz and my 3GS works fine all the time. However, at my work, the wireless network connection works UNTIL it gets into sleep mode. Once it goes to sleep mode and comes back from it,wifi does not work at all - it loses connection to router.
All of the above issues!!!! I had a 3g and never had a single wifi or network problem... Now I have a 3gs and all of the above issues... I even went to the apple store, got a new 3gs but same issues....
I just replaced my phone (3GS) as well after trying seemingly everything else...nothing worked (including getting a replacement). FWIW, my original iPhone works just fine.
I had same problem with my 3g os 3.01 , it started after upgrade from os 3.0 which was great , after one hour of upgrade it went out , I tried all ways stated in the net but no way , my case is not gray wifi , everything is normal but no wifi detection at all at home , work and everywhere , my question is is it hardware defect or software ?
I had the symtoms of fluctuating signal when sitting in front of my router and never getting a fast connection, all that seemingly after the last update. Tech support said System Reset which did nothing. I went to my router settings (linksys wrt310r) and changed it from using G and N to N only. After that BOOM, great steady signal and double the speed. Hope this helps!
Here is something odd. Nothing but problems with my Linksys and wifi but if I use my mifi I have from Sprint using it's wifi it works perfect. Why does it hate our home routers so much. I find it odd.
I have a D-Link DI-524 router and have finally fixed the connection to my iphone 3GS. I went into my router settings and turned off wireless security. On my iphone I went to my wireless network settings and picked "Forget this Network". I then selected my network again and confirmed that a browsing connection was available. Once confirmed I went back into my router settings and turned WPA-TSK back on and set a password. The phone then asked for this password which I entered and it has all been good since.
This is the solution to the Iphone's 3G's that are having problem with the wifi connection.
after that do as a new phone not the old one.
3.DO not restore from any back up's, because if you do all the setting that were on the previous iphone will be overwritten with the new setting so same problem occurs.
Hi
Since I upgraded to 3.1 i can not connect at all to my modem "THOMSON TG585"
I have a 3g which stopped detecting or connecting to wireless networks (not just mine) after the 'upgrade to 3.1.
I've tried to do a factory restore and not restore a backup - guess what? it still doesn't work. So I have to set up the phone from scratch for nothing. Not impressed Apple. The 'expert' at apple services suggested turning off security on wireless networks. Ironically two more iphones were due to be bought within this household just as the 'upgrade' was released. Now both are going for Androids instead. Not that I imagine Apple give a monkey's.
I am having the same problem as everyone else. It all seemed to work until 3.1 came out.
Apple has just got to do something about this. It is maddening. I am now trying to daisy chain an older linksys router to my time capsule just for the iphones to run off of. Problem is now my computers and printers are all screwed up as none are working off the same network connection. Well tonight the battle will continue.
So I'm not the only one as Apple would like me to believe. My 3G has worked brilliantly for 6 months until upgrading(?) to 3.1 now WIFI is abysmal on both my home and office setup. Apple do not want to admit to there being a problem.
way to publish an article about a concern that doesn't apply to you and that you give absolutely no advice for. fucking infuriating.
Just wanted to tell my experience. Which is as bad as (almost) everyone else's. I have the 3G version and after installing 3.1 it started telling me the "incorrect password" thingy once a while. It's driving me nuts! The password definitely is correct and it even allows me to use WiFi for a while until it decides to "forget" it and asks it again... And merry go round...
My Iphone connection is off and on. One time I am connected, next time webpages would not load or emails would not download until I turn off the wifi and use the 3G connection. I have learnt that when my pages are not loading, it must be iphone cannot connect to my linksys wrvs4400n router. It is an iphone problem decause I have a laptop downstairs which never lost connection at any time. Could it be an encryption problem? Right now I used the wpa personal, may be a lower encryption.
I have a ntgear router... cant remember the model no., but it works excellent with my laptop even from 2 houses away... my iphone 3g however... seems to lower and then raise the wifi connection speed for some reason... the first time i used it the connection speed was great... i had it for about 2 weeks now and well this happens...
I have recently had a problem with my iphone, after installing the latest update wifi was removed as an option from my phone. After several attempts at resetting my phone and router I took it back to the shop I bought it from. They couldn't get it to work work so now it's on it's way to Apple land. It had better come back in the same immacculate condition as I sent it in.
Like everyone I have same issue with no wifi or disconnects all the time after I upgrade to 3.0 and 2.2.1 works perfect, I just upgade my 2G iphone to 3.1.2 and fixs the problem.
I just bought a DLink DIR-825 and am running into the periodic "incorrect wifi password" problem. Sometimes it happens repeatedly within a few minutes. Other times will go for several minutes without a problem.
I've tried every available permutation of WPA, WPA2, AES and TKIP on the router. Nothing seems to help.
What has worked for me is to use WEP instead, or no encryption.
I can't tell if this is an Apple problem or DLink problem. I did not have this problem with my old router, a D-Link DI-524.
I have the same problem with flux in my bars. It is horrible and yea even right next to router. I'm supposed to have 6 MB from AT&T uverse running a cisco ipn4320
Please let me know because it thinking of canceling AT&T if this us it cuz this sucks
I got my iPhone 3Gs three days ago. Wi-Fi shows a constant strong signal, but does not connect to the internet. I use Apple's Airport Extreme base station with several macs working perfectly. All the Wi-Fi is listed and is correct.
Also, Bluetooth works for a while and then suddenly stops. I wasted heaps of time and am not happy.
Also having the same issue with 3g, I have a netgear rangemax router, I'll add this as well, when my phone drops the signal, the signal drops off any laptop that is also connected to the wifi. It's like the iphone is blocking the signals.
Ever since I upgraded to 3.1.2 my iphone 3g will not detect wifi. I've tried resetting the settings on my iphone but nothing will work. It's brand new there shouldn't be any problems with the iphone's hardware.
I started having problems after I upgraded to 3.1 or 3.1.2. iPhone 3G kept dropping my home network. All other devices are working fine. iPhone keeps prompting me for my password, then failing to connect.
When I removed the password (Netgear, WPA security), it would continuously connect and drop. I'd get an IP address for a few seconds, then it would disappear.
Bluetooth is working fine, and I can see my MAC address under network settings.
Have only noticed a problem on my home router (sitting right beside it). Will be trying on other public networks soon, but suspect it is the flaky signal strength problem.
Please help me...I don't know what happened. My iphone 3G just suddenly won't connect to the internet even if it recognizes my home wifi.(It used to work perfectly whever there's wifi) I already brought it to Globe Telecom Center (official Philippine Iphone distributor), and it worked there just fine. I really am so frustrated, had the iphone for a year already, and I don't know if some kind of warranty covers it. I've tried everything there is over the web to solve it, still efforts aren't solving it.
I too am having this issue, starting today. Nothing has changed so can't figure why this suddenly happened. I have a 3G that's about 15 months old, all software is up to date. Network works fine for all our computers except for the 3G today. Now that I think of it, my husband's 3Gs was doing this earlier in the week, again, out of the blue.
So, why doesn't Apple have an answer for this if all of us have have this problem, and it appears to have started for some people in July?
i have a iphone and even when im right next to the router the wifi disconects the reconects then it does the same problem over and over until a while later it just doesnt even show the router name at all!!! and im standing right next to it!!! my router is BelkinG+208122... help pls
I am getting the same problems, tried everything, wasted 5 hours on this and I got exams period now. Need my phone too though. I really would not buy or tell anyone to buy any apple products, these are really crap. I am tired and that's it. Apple got my money and I lost my good old Nokia thing for this shit. :(
I got my iPhone (3gs) yesterday (11/16/2009) and it keeps forgetting my home network's wifi password. It is annoying and irritating to enter the 35-character password every time as there is no way to save it... I hate this feature...
I belive the problems we are all having are heat related. Try this then post your results. Place your iphones on cloth covered ice pack to chill, say five minutes. then connect wifi. i believe you will find it will now connect. problem is the firmware upgrade has changed power and internal heat characteristic and causes this drop out. if im right we need a clever soul to tell us how to rectify.
Hi. I'm having a similar problem. In my case, the wifi opiton in setting has been greyed out. When i checked the network option, it says NA. Any suggestions.
I've had my Iphone 3GS 16GB for about 4 weeks. Today it doesn't see my wireless router. Even though my other 3G iphone and 2 laptops do. Pretty pi%^ed off about it.
My 3g just gave up on wifi altogether whether it's at home, school or a friend's home network.
Had my 3GS 4 days. Initially picked up my home wireless no problem. Still picks up other wireless, have logged on to friends wireless at their homes to use icall, but at my house no. My wife's 3G, no problem, our two laptops, no problem.
I spent hours on the phone with apple yesterday. Came down to disabling my router security, connecting to the wireless with the 3GS (no problem), then resetting the router security and password, and entering the new wifi password in both phones. Problem solved, until I came home from my friends house tonight (his wireless, no problem). I get home and same problem as before. My phone
recognizes our home wireless network, but will not connect unless I disable the WPA2 security, it wont accept the password. After I disable the router security and set a new password for the router, enter it in both phones to reconnect, all is good. I expect my wife's phone will be fine with our home wireless tomorrow, and mine will not. Unacceptable. Apple>Fail or D-Link>Fail. I suspect Apple>Fail.
Sounds like "foil hat brigade" talk, but wi-fi problems eliminate usage of VOIP apps like icall, win-win for Apple and AT&T.
I'm ready to return this piece of Es H Ai Tee Ee and get a droid (other reasons as well, jailbreak is seeming more and more a great idea).
Any feedback/ideas welcome.
My router is a D-Link WBR-1310
I have a 2G and a 3Gs side by side and airplane mode except for wireless turned on, and I am unhappy to report that the 3GS stops downloading information and loses connection to the internet while the 2G is lightning fast. Very disappointed....
Hi .... today I upgraded the firmware of the eugenius gigabit repeater... but still problems in the fluctuation of the signal. It already costed me too much. I even tried to add a special antenna but even more worse results...
My question -- there are so many iphones sold worldwide, and there are so many issues about this problems.
WHEN WILL APPLE DO SOMETHING ABOUT THIS.
The G and 3G are realy great, don't want another phone anymore.. Mailing to them will not give you a reply and if they do its'not about the problem.
Ho Ho HO ...... Santa is coming to town (maybe with an special free add-on for the Iphone? Or shall I keep on dreaming.
Yesterday I did a restore of my iPhone since I had 500 MB of "other files" and wanted to get rid of it.
Not only that I lost ALL settings of ALL apps, e-mail accounts, IM accounts etc. ...
Now, when I set up my WiFi (fixed IP, WPA), the internet connection works exactly ONE time, that is if I do some internet activity RIGHT AFTER setting WiFi up.
As soon as I leave IM+, Safari or whatever I do, no app gets any internet connection until I define the WiFi connection another time.
That goes on for hours now.
Rebooting didn't help, and a restore is not what I want to experience again.
I noticed that the restore got stock at the point where only the standard app icons were back again, on Windows one of those two processes that always crash when using iTunes (Mobile Device Helper and another) crashed, and the restore process wouldn't complete until I disconnected and reconnected the iPhone.
Before the restore, everything worked just fine.
I'm SOOOO p*ssed off!!
Any idea what the problem is?
Oh, 3GS, OS 3.1.2
hi! my iphone seemed to be working fine for a year. i can connect pretty easily anywhwere with a wifi connection even at my friend's house. but 2 days ago, it doesnt seem to work anymore. i tried reseting the network settings but i stil cant connect. sometimes it can detect the wifi connection but when i tap on it and try to connect, it just says unable to connect. i also cant connect to other wifi places, not only in my house. HELP! :(
iPhone 3G running OS3.1.2 - Linksys wrt54g ver 2
(also happens on other routers)
Signal strength often flucuates, distance from router does not seem to be the issue. Once connection is lost I have to cancel the connection to continue using the device. When signal strength returns enough to reconnect, I am forced to enter the password again. This service loss wouldn't be nearly as aggravating if it would allow me to try the reconnection with the previous password (which it seems to think is incorrect, but I know it isn't). I am so tired of constantly rekeying in my password.
I have an iTouch 3G with OS ver 3.1.1 and it constantly forgets my WiFi password.
My GF has a iTouch 2G and she has no problems
Tried resting phone and changing channel # on the AP
but no luck :-(
I returned my 3G Iphone to the Exeter UK store yesterday (a three hour journey for me) after speaking to their technical engineers and going through all the proceedures that others
on this blog have been encouraged to do. I explained the problems with wifi dropouts and the apparent "deafness" of the wifi receiver after upgrading to firmware issue 3.1.2.
To their credit the store replaced the handset without argument despite the fact that it was 88 days out of warranty. They didnt admit there was an issue but they were clearly aware that there was and it helped having a print of these blogs!! From my experience one indicator of the type of WIfI problem you may be having is the signal strength received in dBi. The lower the number the stronger the signal.Those with
a strong signal yet still experiencing dropouts may be suffering from a software issue. I suspect my problem was hardware/overheating related in some way conected to firmware 3, as my signal strengths dropped
dramatically (-92dBi) after the upgrade. My replacement handset is working perfectly and as I remember the old one. What a relief!!
will retoring to 3.1.2 solve the problem. i mean a custom firmware! has anybody done in before. mine is a 3g and after retoring to 3.0 the wifi died and is not able to connect any more.
Mine at 1st worked great and I would see my usual 6m speed tests, but since dec 5th 09, none of the speed tests will break 1.6m while 2 other laptops would see 6m with ease...
I'm using a netopia wireless dsl modem with built in 4 port router...
I have uninstalled the speedtest app and re installed it with no changes. my signal in the home is always full of bars yet only ~1.6m speeds..
I purchased my 32g iPhone 3gs the Sunday after thanksgiving if it means anything
I have recently bought an iPod Touch 8GB and promptly upgraded it to update 3.1.2, everything was working fine until the 15th of December when the iPods WiFi stopped working. At first i thought my routers WiFi must have been down, however i tested the connection on my laptop and it worked perfectly well.
I must say i am a little disappointed with Apple as they are usually known for good quality and reliability and, as this is my first Apple product in about four years, i was expecting it to last me quite a few years, now i wish i had just bought a Sony Walkman.
:( Got same as Patty . Iphone 3g 3.0 update to 3.1.2 got problem wifi...
Where in the f*ck does Apple get off producing junk like the iPod Touch.
I have two of them...one early generation and one generation 2.
Neither will stay connected for more than few seconds.
Constant dropouts...on off on off on off...
Apple hardware...overpriced POS.
I have iPhone 3GS, and have noticed this week the WiFi dropouts. I have a Netgear router and run two laptops off it without any issue. I thought it was me, but glad to see it's not! The on/off from Airport mode suggested by Caballera seems to work and is a quick fix.
I have an iPhone 3G running the current software.3.1.2. NOW I'm dropping WiFi. It's worked since I got it. I had a Trendnet N router that I switched out for a D-Link Extreme. Both of those worked fine. But, the D-Link went crazy on its own. I returned it and Got a NetGear 3700. NOW I drop Wifi. It stays connected maybe a minute, then poof. Banging head against wall. Why did I switch routers! Argh.
Totally bummed - spent a good three/four hours painstakingly downloading various versions of iTunes and upgrading my iPod Touch to the most recent version, only to discover that it's disabled my Wi-Fi completely and won't even let me onto the option to select a Wi-Fi connection. Pretty lame, actually, and really disappointing.
I get a maximum of .3 mbit
this is not good enough and should be sorted out
I payed a lot of money for this phone and do nor expect to have to put up with this crap
I was havin this prob and updated my linksys router to a newer linksys and went from 90-300k downloads to 11mbps. No fancy tricks or settings worked for me. Just needed a newer router it was $50 at best buy
I have an iPhone 2G that's been retired (upgraded my son to a 3GS), so essentially it's now an iPod Touch.
It will stay on wifi for as long as it's awake, but if it goes to sleep there's only a small chance (say about 1 in 3) that it will reconnect to our wifi router (an older Dell model). When it works it works great and it stays connected.
When it comes back on after sleep the wifi indicator can show full bars but it just won't talk. Only disabling wifi and re-enabling it will return it to working on wifi. Very annoying, and not at all the "it just works" image that Apple would like us all to believe.
-Noel
Seems Mac is not interested on solving this issues. I've been forwarding this posts regarding network loss. Nothing Worked.
The Scenario (as previous posts):
When Connecting the iPhone to a Wireless it recognizes the setting on general settings but on less than a second, it drop out the connection.
On the otherway, connecting from an application i.e. Safari, it asks for the password again and again.
No Solution!!. I do like my iPhone but this is a MUST HAVE. Next time i'll think twice regarding buying me an iPhone.
Happy New Year everyone!
Iphone 3GS 32gb. Purchased just before christmas and it constantly drops my home wireless or shows a connection with 1 bar. I also get messages from my Apps that It cannot connect the the internet.
I have a Dell Trumobile 1184 wireless router. I sit next to the router and it will not help. Firmware Version 3.1.2 (7D11)
My iPhone 3G wifi has NOT worked AT ALL ANYWHERE since the big 3.0 update in June 2009. This totally blows. I have tried almost EVERY solution mentioned on the net with NO success! This is ridiculous! One of the main things I used the wifi connection for is the apple remote to control iTunes.
Hi there I have a iPhone 3g and I get no wifi connection unless I am right next to the router. I have tryied restoring my phone but it was no different. I know it's not the router or connection as my girlfriend has a 3g with the same software and she can get a full signal all over the house. Any ideas thanks.
Hi everyone,
Been going through the same frustration as everyone else. Using the iPhone 3g with the latest updates. Setting my router to transmit on 11a/b/g/n connections and WPA security seems to have done the trick over the Christmas period. However, I went back to work today and had to use 3g throughout the commute, and on my return home it started dropping the wifi connection again, and keeps asking for the password.
So I took out a big empty box, gave it the made-up name of Steve Jobs and kicked it to shreds! Still no wifi, but I feel much better and ready to trawl some more forums...
I have the exact same problem as Freiteez. About a week ago, I noticed my Iphone 3G was no longer trying to connect to my home wifi. It cannot be the router as nobody else in the house is having connection issues. I tried to Reset Network Settings and that did not help. I downloaded OS 3.1.2 and it still doesn't work. I tried to google a solution. It seems there are many with this problem, but no one knows what to do.
My iPhone 3G is not connecting to any router so i tried another iPhone an it connected, so i reseted the network settings but nothing worked can any one help please and thank you.
My experience with this issue is that it starts when I update some applications from iTunes. It happend with my home WiFi first. But WiFi of my parrent's worked well, until I updated applications. During the update it started to fluctuate between one and full bars. I am not sure, but I think that it is not related to any update of iPhone OS because it worked well after my last update for couple of weeks (also iTune updates worked) and started to not work with no clear reason. Mabye it is because we all have some weird application or game installed?
About 2 months I got an IPhone 3GS with O2 (UK network provider). Set up wifi without a hitch, but then over the Christmas period I lost wifi connection (yet the phone was still able to see my network and neighbours as well), no settings had been changed on the phone or router and yet I was getting everything from unable to scan networks to unable to connect to network. I tried everything from restoring the phone, resetting the network settings on the phone, changing the routers wifi settings, changing the SSID name, disabling the security...absolutely everything and I have even purchased a new router to see if it was a router problem. I was still unable to connect and as you could imagine I was at my wits end. I must have spent the best part of 6 hours and £100 (about $160) However by chance, I went back to old router, changed the security to WPA2, changed my network name to one which had no fullstops and no spaces, changed the wireless mode to "g" and changed the wireless channel from 6 to 1. Bugger me (not literaly!) straight onto a solid, no dropping wifi connection. I had thought it was the iphone antenna fault which I had read about as possibly being faulty. However, a visit to my local coffee shop proved that the Iphone antenna was still working. Anyway, apologies for the long post but I hope this entry helps
FIVE EASY STEPS TO RESTORING THE WI-FI SIGNAL TO YOUR IPHONE...
Hello,
I haven't looked through all the earlier posts, so don't know if this has been said already, but...
For those with Netgear routers and Wi-Fi issues I can certainly report what worked for me...
1) Your iPhone is just like a laptop trying to connect to the Wi-Fi internet
2) Occasionally it drops the signal
3) When my laptop does this I instantly go to switch the router OFF and ON again (it's an old IT trick I picked up)
4) Take you iPhone with you and wait for the signal to come back up while sitting close to the router
5) Bingo! Before long you get your proper Wi_Fi three bars restored and your iPhone with Wi-Fi is ready to go until the next time the signald drops, in which case repeat steps 1-5 above.
PS: I'm keeping my fingers crossed here because it's only a few hours since I discovered this iPhone issue was the same as with a laptop...
I have exactly the same problem as Freiteez.
Just this weekend i noticed i wasnt connecting to my WIFI from my iphone 3GS (running 3.1.2). My wifi doesnt work AT ALL on my phone now, and I had been using it fine with no problem at all for the past 3mths.
The WIFI searches for networks and it cant find any at all. It used to come up with 2 or 3 whenever I was passing homes etc even in a shopping centre or cafe it doesnt show anything at all. Tried to manually add the the network but it still couldn't be located when searching for networks to join. Not sure what triggered this problem. It's very very strange. I love my iphone but my Nokia used to be much faster. Even the reception was better.
typed wrong email address before. I am sending this again with proper details just in case you have a solution and can email to me. Thanks!
Change your beacon settings in your router to 1000 (or as high as you can). I did and it solved the slow connection issue for me.
I think Sarge is on to something. At my office, my 3gs could barely pull 300kbps until I began messing with the beacon interval setting. On that router, the lower I set the beacon, the faster my connection speed. Unfortunately, my cheap netgear router at home doesn't allow me to config the beacon interval.
Hey. I just got the same problem as Freiteez and Hannah.
My iphone is no longer getting any wi fi connections. Used to pick more than one connection. Now its impossible to get one. Could anyone pleaaaseeee help me out with this problem.
Thanks a lot.
hi, I have an i-phone 2g cell.When ever i connect it with my wifi router it connects but after a while it disconnects.So, everry time i have to go to settings and connect it to my router again.It never connects auotmatically but itself.help me.
I have a 3g unlocked iphone and I have never got a wifi network. I have tried the network reset as well as using push fix and nothing seems to work. It is showing a wifi address in my general phone settings but it has yet to get wifi. If anyone has any ideas what I can do or check to get wifi please let me know
I cannot believe this is still an issue. My contract is due for renewal in 5 months - guess what I won't be getting next time.
From Australia, ever since I updated my software (to 3.0?), the wifi works randomly every month or so for a few minutes. Given that I have only a limited amount of data I can download from 3G, this is extremely frustrating. Now I can't use wifi to download any games from itunes.
Hi all,
I've been having issues with my 3gs (OS 3.1.2) not switching to wi-fi from 3G or Edge when I'm at home. I did a bit of research on some Netgear forums (I have an older Netgear wireless router) after seeing Sarge's and JSH's posts.
The forums mentioned that by changing your wireless router's "mode" to "g-only", instead of the default "g and b", you can effectively increase the beacon count. I assume the beacon count affects how often the router sends it's SSID for wireless devices to view.
Regardless, this is working for me today ... wi-fi always attached. Hope this helps folks.
I have that problem with my 3gs it's so slow when I'm using my wifi and I know it's not the wifi cause I also have a 3g iPhone and it runs fine in wifi so I don't know what to do?
They may be great 'gizmos' to have, but iPhones, especially lately, have been proving largely problematic. Has style now over-ridden substance? Has Apple's mass success made them get lazy? This article at The Music Void sums it up perfectly - have a read. Agree or disagree? http://bit.ly/aML9UT
My two boys both have identical iPOD Touches. Both have all the same software revisions and settings. One works great with our wireless router and stays connected to the internet with no problems. The other drops the internet every few minutes and has to be reset before it works again. Sounds like a problem that can only be fixed by returning the iPOD until you get lucky and find one that works good.
New replacement iPhone 3GS. Wireless worked great at the Apple Store, at home after upgrading to new 3.1 software and connecting to home network, wireless connection is slow to dead. I can run speed tests and max out at 10mbs! But most tests ut spikes than drops to zero before the test ends. I had no problems with my other phone on thus network.
I show full bars eventhough I can't connect using safari. Email and AppStore and iTunes seem to be working well too.
Running a cable modem/router. Motorola Surfboard on Comcast system.
Any tips, thoughts or fixes? Please email.
I have a Motorola Surfboard
Pages
