iPhone 101: How to Maximize iPhone Battery Performance
battery_max
Poor battery life and iPhone are a few words that get mixed together all too often it seems. While some will say it's fine, others will say it's pitiful. As many of you know, battery life will fluctuate greatly between users and their individual usage patterns but TiPb wants to provide you with some simple tips and tricks on conditioning your battery to provide a maximum life and squeezing as much usage out of each charge as possible.
The battery in an iPhone is a lithium-based battery which is most common in consumer portable devices. A lithium-ion battery provides 300-500 discharge/charge cycles in its lifetime and the following tips are just a few ways to efficiently gain longer battery lifespans while extending overall battery life of your iPhone.
  • Be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down).
  • Always be on the latest software from Apple, 3.1 currently, as engineers may just find new ways to improve battery life.
  • Avoid heat - do not leave your iPhone in a hot car or in direct sunlight.
  • Optimization of your settings. Yes, some of these are no brainers but can be effective. Simple things like:
  1. turning off Location Services,
  2. turning off Wi-Fi and Bluetooth when not in use,
  3. fetching new data less frequently,
  4. setting the brightness of your screen below 50%,
  5. turning of the EQ while listening to music,
  6. turning off 3G while not surfing the internet (Yes, we said it...)
All of these add up to better battery life.
After you've tried some of the above tips and you are still not happy or your battery life is just horrid all together, you may want to try restoring your iPhone and do not restore from a backup file but rather restore as a new iPhone. All too often we hear about horrible battery life striking many of you after updating your iPhone to the latest software. If this is the case, 9 times out of 10 a separate restore as a new iPhone will clear up your battery issue.
Have some battery saving tips you'd like to share? Leave them in the comments for others to take advantage of!
Jeremy
Community editor. Tech enthusiast. All-around geek.
More Posts
loading...
loading...
loading...
loading...
← Previously
Poll: FCC to Announce "Net Neutrality" Today. You Want?
Next up →
UPDATED: AT&T 3G MicroCell Site is Live
There are 56 comments. Add yours.
Angel says:
Those are all fine suggestions but for a non-jailbroken phone the items listed under "Optimization of your settings" are cumbersome to access. Flipping those settings on and off all the time requires a lot of steps. There's isn't an "optimized way" to "optimize your settings".
sting7k says:
Summary, don't use any of the fun and highly useful features of your iPhone.
FresYes says:
It would be great if there were an app that turned off all the battery sucking features kind of like a 'macro'
YougB says:
Set Wifi to "ask to join"
I think the factor I notice most often is proximity to good cell towers, which is out of our control most of the time. The better the reception the longer my battery life. If I am on the interstate in a remote area, or a back highway, my battery life dives no matter what I do, due to the phone's attempts to improve signal. I can go 2 days or so around the city (major metropolitan) with regular use (talk, browse, music) and not have to charge, but after a full charge take a 5 hr car trip and its red lining.
steve says:
I agree! i'm inside an office building and i get about 2-3 3G bars at best, sometimes it will drop to edge and not ever back on 3g until i'm outside with 5 bars. I believe that when i am inside the phone uses more power trying to get the best signal. Too bad we dont have settings to only use 3g for data only, and then switch to Edge for talk or standby.
Kai says:
  1. Have a spare USB cable at work!
dmackdaddy says:
Location services alone sucks 20-30% of your battery in my tests. Turning off Push is key. I only turn on BT when I need it.
Dev says:
The settings this article tells you to turn off are all settings that require the phone to passively search for the strongest signals (e.g, Bluetooth, WiFi, location triangulation, email/data fetching, 3G towers vs EDGE/2G towers, etc.). All these features mean processing your phone is doing passively, without you actively telling it to do so. Therefore, it all adds up to your phone using battery power when you aren't even using it (i.e., like on a phone call or browsing the web).
This is one of the core issues of the iPhone. Why buy a phone if you have to turn everything off? In my opinion, the whole concept of a smart phone is to have everything ready at your finger tips - not to have to toggle things on/off to be able access to them. If that's the case, there's no difference between the iPhone and a netbook with 3G capability other than form factor.
I'm an iPhone fanboi, but the phone is still flawed.
studangerous says:
Li-ion batteries hate being fully duscharged and will maintain a long life span if you try and top up the battery as often as possible. Rule of thumb is to charge whenever you can and only discharge fully when you are doing the monthly battery meter recalubration.
BBYM#IM says:
I do these tips all the time and SBSETTINGS IS THE EASIEST WAY OF DOING IT!
rebo says:
I was turning off Location Services much of the time, until I realized that this impairs the functionality of "Find My iPhone" thru MobileMe.
matt says:
im way more concerned with my iphone 3g going into a coma 1x a day since i downloaded the 3.1 update. that is the real issue apple needs to be looking into IMO
Appleking says:
Now why the hell should I have to turn off 3g? If that's the case the iphone shoulda stayed edge only.
rick says:
in other words, don't use it...
Eznir says:
This is ridiculous, Apple just should design and for a proper battery.
Amir says:
Yeah, sure, just turn it off! if i wanted a phone that can't do stuff i would have bough windows mobile.
Frank says:
I've noticed that turning off WiFi does mess with certain apps (e-mail, apps that use internet, etc) pre-3.0. Same thing for location services. I'm unfortunate in that I moved out of a 3G area, and the nearest I can get to a 3G tower requires me to go 10 miles up the interstate. :(
Brightness is about the best thing to save your battery life.
Big Pimpin says:
So, in other words, you have to take your "premiere" phone on the market NOT use any of the functions that make it premiere?? My Bold would go all day without any problems, switching back and forth on its own. I could leave on Bluetooth, WI-FI, 3G, everything, and still not worry about it. Apple has REFUSED to do anyting about this since iPhone 1, and they are STILL refusing to fix this problem. My wife updated her 3GS , and now she drops 3-4% each time she sends a single txt message. That's real nice. Instead of all these OS tweeks, FIX THE DAMN BATTERY ALREADY!!!.
Steve says:
Why Apple will not start to think on an iPhone with the possibility to change the battery? Exactly like the rest of the cells world...
Bones says:
Has anyone seen improvements (to 3.0.1 levels) from doing a fresh 3.1 install rather than just an upgrade?
JunkYardDog8113 says:
Why did I buy an iPhone..... Oh Yeah so I have to shut all it's features off.
Between apple and AT&T, ....useless rants I guess.
sfditty says:
Regarding this tip:
I've seen two versions of this. One, as above, is to do the full battery drain down to the "out of charge" screen once a month. I've seen another indicating to go through a full charge "cycle" once a month, but never let your battery drain down do the "out of charge screen, and not down to the 20% marker if you can help it.
So it comes down to who you ask. Expert 1 says do option A, and Expert 2 says never do option A. BTW I did the monthly full power-down to the "out of charge" screen with my 3G, but not with my 1st Gen, and I'm not doing it with my 3GS. I'm not sure if it was related to the "monthly charge-down" strategy or not, but by the after around a full year of use, I was noticing significantly less usage per full charge on my 3G, as compared to my 1st Gen after a year of use.
Mike says:
This is a joke....
Turn off 3G when not surfing the internet?!? LOL. Yes that makes sense but so much for shelling out that cash for an iPhone "3G" or "3G"S.
I own both a BlackBerry and an iPod and I use them simultaneously and I just keep seeing more and more reasons why owning two devices is far superior to owning one device - in this case an iPhone 3GS.
I might be wrong on this one but you FINALLY got push notifications... at the cost of decent battery life (I'm referring to item 3 in this article's list).
I'm just so sick and tired of iPhone worshippers telling me to get an iPhone when other smart phones are doing for years what the iPhone finally got after a half dozen software updates... Oh wait, there was an app for that!
mystic says:
I'm actually amazed at how great the battery life is on the 3GS. I have 3G, location services, push notifications, wifi and bluetooth turned on all day, with the screen set to default brightness, and I ALWAYS get through the day with a little room to spare.
Bear in mind, that TALK TIME on just about any 3G phone is limited to 5-6 hours, so if you spend a lot of time on the phone each day, in conjunction with games, data or video, you're going to eat through batteries quickly. Find a way to top it up - there are a bazillion ways - or modify your usage
Having said that, I see a lot of whining on here from people who:
a) don't own an iphone
b) own an iPhone and are too dim to top up the battery when needed
c) have jailbroken their iPhones and then want sympathy when it doesn't work properly
d) have an axe to grind against the iPhone and don't mind perpetuating a bit of FUD
e) God, I'm too bored to continue.
Every time Apple releases a new phone/update we get the kind of rubbish that is written in this thread.
@Mike. Take your FUD elsewhere.
Mike says:
@mystic... Just voicing my POV. If Apple had a product that didn't require a lot of tweaks just to run nice n smooth I would have an iPhone as well.
I'm not hating. I'm just pointing out the flaws that everybody is trying to sweep under the rug because they want to hail the iPhone as the greatest smart phone around. I won't deny that it is a good looking phone and IMHO it has the best touch screen around. But, at this point that's the only thing it has over other smart phones.
Lithium says:
For $1000+ PER YEAR/ apple better get on dis bit-ch and fix it! I just noticed my battery's down to half after 6 hours of pretty much all standby. This is BS!
Mystic says:
"I’m not hating. I’m just pointing out the flaws that everybody is trying to sweep under the rug because they want to hail the iPhone as the greatest smart phone around. I won’t deny that it is a good looking phone and IMHO it has the best touch screen around. But, at this point that’s the only thing it has over other smart phones."
My 3GS runs beautifully without ANY tweaks. That's why the iPhone is streets ahead of other smartphones in independent surveys of customer satisfaction. And if you believe that having the best touchscreen is the ONLY advantage the iPhone has, you're living in cloud-cuckoo land. As I said, the vast majority of iPhone owners are absolutely delighted, contrary to all the negative stories that are constantly being spun on the interwebs.
Bones says:
I know this would be an embarrassment for Apple, but I sure would be a lot happier if they'd let me roll back to 3.0.1 until they get 3.1.1 out. Right now this upgrade is pretty hard to defend.
frog says:
The iPhone battery life is brilliant. The problem is how useful the iPhone is, and how that has lead to dramatic increases in usage.
I've been through days were I've used my iPhone for 8 hours in a single day! I'd be lucky to use my old phone for, maybe a few hours - usually alot less.
I know someone who just uses it like a normal phone, and only has to charge it once a week.
Miles says:
These tips would be fine if the settings were easy to get to. I can't imagine having to go into settings and then into wifi to toggle it on and off each time I want to use the internet, it's just not a reasonable thing to expect. It wouldn't be as bad if there were little buttons on the top bar to toggle these settings.
Bones says:
These tips would be fine if they addressed the problem. Battery life complaints are one thing when you're using Push, 3G, and GPS all day, but when a software 'upgrade' results in noticeable and unacceptable battery drain - something is clearly wrong... and it's not a setting. Throw us a bone Apple.
Dude says:
I’d just like to remind everyone today is the last day of summer and I have yet to have MMS…that is all.
Joseph says:
So, let's see. What does one do when his/her iPhone/itouch battery goes, we send it in to Apple?
Christin says:
Screen Brightness is the only change I make, and I don't even notice it in terms of functionality (unless I'm in the sun). Turning my brightness down helps soooo much.
skipster#im says:
Someone answer me this, if restoring as a "new" iphone is supposed to help do you lose all of your apps, music, photos etc?
Mav says:
I have never had batery problems with 3G or 3GS. If anything, the battery life got better with 3.0/3.1. One thing to keep in mind: I use iPhone a LOT more then any phone before it. Naturally, the battery has to be charged more frequently. I don't mind charging it once a day or whenever I have a chance. Secondly, you have to realize that iPhone is a mini-computer, after all. How many hours of heavy usage a laptop will last without being charged?
bugs says:
hey buy the current technology but you can use it for 10 min then carry wires/charges with you.
or turn everything off make it barely usable and then it lasts an hr.
i move the mentality behind this.
bugs says:
p.s
just buy a raza phone they last 10x longer on battery then if thats the case, and its free!
Ivan Williams says:
...the only feature I say to adjust, is your screen brightness.
Ivan Williams says:
@scoop you have to just re-sync them. But, of course that means logging into them and settings them up again.
J-Red hates Steve job's says:
Dam everyone who complaining about this problem just jailbreak your dam iPhone and find the soulotion yourself instead Of complaing to apple. LIKE THEIR REALLY GONNA HELP YOU!!!!! THEY WANT MONEY!!!!! Once you jailbreak your phone there are plenty of battery conseverstion application that will extend your battery to limits you never imagine! For example! There's an app called SBS settings "for those jailbroken already know this" with a simple tap of the status bar, you the time and signal and shyt yea lol! It will pull down a page of all your toggles such as, Bluetooth, 3g/edge on or off, wifi and possibly everything that can me switched on and off including respring. I'm telling you once you get it set up which is very easy you will have signifcant battery improvement cause you iPhone will learn to adjust to the settings thus improving battery life when needed.
Bill McNeely says:
Responding to Bugs posting... I have a solution. Instead of turning off every conceivable feature on the iPhone, just go out and buy a 1900MaH wireless charger sold by www.3gpower2.com. The portable power charger is ready to go out of the box. The device will recharge in less than 4 hours and will hold a charge for 6 months. It even has a handy LED light to let you know how much charge is left. Purchase for just $38 as compared to $45-$60.
larry campc says:
Brand new, never used.
- Sent straight from from Iphone USA
- Come with a pouch, data cable, stereo headset, home charger
- Manufacturer warranty
This is a brand new never used Iphone 3GS . Still has the sticker on it with pictures to prove it. Comes with a full year warranty along with an extra in box never used pouch.
Brand New and unlocked to all networks..
Comes with full 12 months international warranty.
Sealed with complete accessories.
SAMSUNG Omnia 2
SAMSUNG Omnia I8910 HD
For more information, send us an email: : mobileshoponlinelimited@gmail.com
larry campc says:
They are Brand New, Unlocked, Original, Full accessories and come with
1 yr International waranty from the Manufacturer
Nokia 5800 XpressMusic...........$250
SAMSUNG I900 Omnia...............$250
SAMSUNG Omnia 2...............$330
SAMSUNG Omnia I8910 HD...............$350
SAMSUNG I8510 innov8 8gb..........$230
NOKIA N96 16 GB................$300
NOKIA N86 8mp................$330
Sony Ericsson Aino.....$350
SONY ERICSSON x1....$250
SONY ERICSSON x3....$350
Sony Ericsson Idou...$350
Sony Ericsson C905 ....$250
HTC TOUCH DIAMOND........$300
HTC TYTN ....$290USD
Apple iphone 8GB 3g ...........$300
Apple iphone 16GB 3g..........$330
Apple iphone 32GB 3gs...........$500
Apple iphone 16GB 3gs..........$400
BlackBerry Bold 9000....$350
BlackBerry 9500....$360
Apple iphone 8GB...........$270
Apple iphone 16GB..........$290
Sony Ps3 .....................$300
Nokia E71.....................$300
Nokia N85 ...................$280
Nokia N97....................$330
Here is our Contact
Email: mobileshoponlinelimited@gmail.com
Legit Forum Seller Registered No. 04501084
Omari James says:
When you lock your screen, make sure you close the app you have open. It still is running when the screen is locked.
tehsc says:
HEy guyz!! do not believe mobileshoponline limited!!! they r the biggest
scam ever!!! they never really sell phone just want to cheat ur money!!
Any detail u want u just post here i will give u..
But 1st of all never buy from Mobileshoponlinelimited.
I know i m a fool and i have been cheated 2500GBP, so i dont want any
other people gt cheated!!
Please spread around!!!warn ur friends and warn the world!!
akmatic says:
i can't believe how many people are put off by these tips! same thing with the g1 - battery life sucked (actually worse than the iphone) so the advice was to turn off the stuff that sucks power when you're not using it. and then 2/3rds of the responses are "that's why I have the phone, i shouldn't have to turn it off!" good gawd it isn't that hard to toggle stuff on/off and it makes sense to do so. you don't need 3g to send txts or im's nor do you need wifi. turn it on only when you need it. it doesn't make the phone any less functional. no one is saying never use wifi or bluetooth or 3g.
fact is if you want a tiny phone that is still a smartphone its not going to have a crazy battery. pure and simple. get over it and stop crying.
DJOKO TRISANTO says:
They are all brand new with the complete accessories in original factory sealed box 100% original and comes with 12 months international warranty. .
( Store Promotional Sales Offer - Buy 2 Units And Get 1 Unit FREE )
APPLE IPHONE (3GS) 32GB at $300
APPLE IPHONE (3GS) 16GB at $280
APPLE IPHONE (3GS) 8GB at $270
APPLE IPHONE 3G 16GB - $260
APPLE IPHONE 3G 8GB - $240
Nokia E90 Commnuicator at $270USD
Nokia N96 16GB at $330USD
Nokia N97 32GB at $360USD
Nokia 5800 XpressMusic at $280USD
Samsung i900 Omnia 8GB.$260USD
Samsung i900 Omnia 16GB.$280USD
HTC Hero at $320USD
HTC Diamond at $270USD
HTC Touch PRO2 at $290USD
Sony Ericsson Xperia at $270USD
Sony Ericsson W995 at $280USD
Sony Ericsson Satio (8GB) at $300USD
Blackberry Bold 9000 at $270USD
BlackBerry 8830 $230USD
Blackberry Curve 8350i at $230USD
Blackberry Storm 9500 Touch Screen at $290USD
Blackberry Storm 9530 at $300USD
BlackBerry Javelin 8900 at $280USD
Blackberry Thunder 9500 at $300USD
2x CDJ 1000MK3 + 1 DJM 800 DJ PACKAGE.......$1,500
BONANZA:
Buy 2 units and get 1 unit FREE.
Buy 5 units and get 2 unit FREE including shipping.
Please contact us for more information and purchase inquiries:
MR Djoko Trisanto (MARKETTING MANAGER)
SKYPE ID:Anthony.mark1
EMAILS : Market2buy@hotmail.com
Tel:+447035965778
IN GOD WE TRUST
MrGizmo.se says:
Great summery. But I think it weird that modern battery need this handle to maximixe battery time, dont you?
iBchillin says:
I wonder why of all the tips they list, they don't tell you to just hit the sleep button on top of the phone. I think that was one of the first tips Apple suggested when you are not using your phone.
iphone applications development says:
The biggest drain on the iPhone battery is Push Notification, esp in emails that are set to push. Set your settings to fetch from the server rather than have it pushed to the phone. Try setting it to fetch hourly or simply fetch manually. It will surely help save you battery.
Julienne Leno says:
I have observed my Nokia 5800 XpressMusic cell to be the finest overall I have owned. Just wish it had a slide out qwerty keyboard! Anyway, it doesn't so more than enough is enough. A good deal of individuals whine about the digital camera, it does suck, but it is not that critical to me-I possess a excellent Canon SD950 camera if I want pics. I'm genuinely please with how customizable it really is and every one of the factors I can perform with it. Needs charging practically daily when utilised a fair bit. Pondering about debranding it. Rogers (Canada) keeps items rather locked down and the highest fw I have been able to upgrade to is v30 (anything like that can't remember the exact quantity at the moment). Sounds like v40 has some good characteristics I'm missing out on.Properly, glad I identified this forum, I hope to learn a good deal far more about what I can do with my phone.
