You iPhone supports fast charging, you just can't achieve it with the charger Apple's provides you. Rather than forking out a ton for Apple's official USB-C to Lightning cable and USB-C wall plug, you can save by going for UGREEN's affordable alternatives. Both UGREEN's USB-C Wall Charger and USB-C to Lightning Cable are discounted by 20%, all you have to do is enter the right coupon during checkout.
Plug in
UGREEN USB-C Wall Charger
With 18W Power Delivery support, this affordable charger can power you Nintendo Switch, iPad Pro, or iPhone 8 or newer with the right cable.
$12.79 $15.99 $3 off
With coupon: UGREEN49
Charge up
UGREEN USB-C to Lightning Cable
Speaking of cables... This is the one you'll need to get your modern iPhone to fast charge, like going from 0% to 50% in thirty minutes. Clip the on-page coupon and enter the below code for the full discount.
$10.49 $13.99 $4 off
With coupon: UGREENCB
If you want to power up your iPhone 8 or newer quickly, you need the correct charger. The USB-C Wall Charger from UGREEN supports 18W Power Delivery so will work great with a USB-C to Lighting cable or with a regular USB-C cable for your Nintendo Switch or iPad Pro. It usually sells for $16 but drops to $12.79 when you enter code UGREEN49 during checkout, saving you 20%. It has a compact design and built-in safeguards against over-voltage, over-heating, short-circuiting, and more.
You may need a new cable if you want to enable fast charging on your iPhone, and UGREEN's USB-C to Lightning cable is a great option. Clipping the on-page coupon for 5% off and entering UGREENCB at checkout drops it down to only $10.49. We have seen it go about $1 lower before, but it is MFi-certified and more affordable than Apple's own option despite its more durable design.
