Best iPhone 12 Pro Battery Cases iMore 2021
The iPhone 12 Pro battery is a formidable powerhouse that sometimes lasts all day! But heavy users may find that even this battery won't last during long trips or heavy workdays. If you need an extra bit of juice to get your iPhone through the last few hours of the day, check out the best iPhone 12 Pro battery cases to get the job done.
- MagSafe FTW!: Charge Fast MagSafe Power Pack
- Power + protection: ZeroLemon Battery Case
- Kickstand included: Zttopo Battery Case
- Best value: Geameon Battery Case
- All the pretty colors: JERSS Battery Case
- Easy install: Allezru Battery Case
- Slim pick: Alpatronix Battery Case
- Removeable power: Mophie Juice Pack
Staff PickThis is one of the most exciting accessories I've seen for Apple's new MagSafe technology. The magnetic battery pack implements the MagSafe system to snap onto the back of any iPhone 12 model and MagSafe case to deliver 5,000mAh of fast-charging juice. When it's done, just take it off and put it away for next time. The Charge Fast Power Pack supports simultaneous wireless charging as well.
If you need extra protection alongside extra battery power, the ZeroLemon Case is for you. This one has reinforced corners and raised edges around the screen and camera for 360-degree drop protection. It adds up to 120% extra battery life to the iPhone 12 Pro and supports wireless charging.
Another 5,000mAh battery case, the Zttopo comes with a nifty kickstand that works in both vertical and horizontal configurations. The Zttopo protects against drops as well as over-charging, but it does not support wireless charging.
The Geameon Battery Case is just that, a simple battery case that can provide double the battery life of your iPhone 12 Pro. This one is the most affordable, but it does require wired charging.
While most battery cases only come in one color (black), the JERSS case comes in several vivid colorways to express your personality. This accessory also provides the biggest battery - a full 7,000mAh of additional battery power.
The Allezru case is built with a soft rubbery outer layer that provides both protection and easy installation. No need to wrestle with this case to get it on and off. The soft material will slip right over your iPhone for a grippy, snug fit.
The slimmest on our list, the Alpatronix is thinner and more lightweight than other battery cases, making it easier to tote around. This is a long-running manufacturer of battery cases that continues to build reliable products over time.
Like the Fast Charge pack, the Mophie Juice Pack can be affixed and removed from your iPhone as needed. However, this one does not work with MagSafe; instead, it uses an adhesive mount to slide and off. The mount doubles as a kickstand when the battery pack is not installed.
Everlasting Juice
With one of the best iPhone 12 Pro battery cases on your phone, your battery life will seem endless. Whether you're traveling, camping, or working long days, you need to count on your iPhone to stay charged as long as you do. We like the Charge Fast Power Pack for easy convenience since it snaps right onto the iPhone 12 Pro using the MagSafe system.
For a thinner, more permanent option, the Alpatronix is a slimmer, lightweight battery case that will more than double your iPhone's battery life. It also comes from a reliable manufacturer that has been producing quality battery cases for years. Any of these cases will prove to be a convenient option to keep your iPhone alive as long as you need it.
Get a wireless charger for hassle-free charging
Want to try out or love the idea of Qi-charging? These are our favorite wireless chargers for iPhone!
Don't let your Apple Watch get damaged; get a case
The best Apple Watch cases can help you avert disaster. You may think you don't need a protective case for your Apple Watch until it gets all scratched up, or worse, cracked. Don't make that mistake. Protect your watch from the elements.
Protect your iPhone 11's screen with a screen protector!
Anytime you buy a new iPhone, it's best to put a screen protector on from the start. If your screen protector breaks, be sure to replace it right away.
