Best iPhone X Battery Cases to Extend Battery Life iMore 2022
Watching YouTube videos, browsing Facebook, sending emails, and making calls are all things we do with our iPhone. Unfortunately, it never seems like there is enough battery life to get it all done in a day. Luckily for all of us, there's a simple solution to keeping your iPhone X charged and always ready to go: a battery case! Not only will a battery case increase your usage time each day, but it also offers a little bit of protection, so your iPhone X stays looking like new!
- Trusted brand: Mophie Juice Pack Air for iPhone X
- Very popular: Lonlif Battery Case for iPhone X
- Low-cost option: Maxboost iPhone X Battery Case
- Built-in wireless charging: Alpatronix BXX Battery Case
- Rugged Protection: EasyACC Rugged Battery Case
- Fashionable: Casely iPhone Charging Case
Staff FavoriteMophie makes some of the best battery cases on the market, and the Mophie Juice Pack Air comes packed with great features you'd expect from a high-end battery case. It's low-profile and ergonomic design makes it easy to hold. The LED indicator lights on the back will show you how much battery you have left in the case. Plus, you can charge your iPhone and the Juice Pack Air at the same time using Qi wireless charging. You don't have to charge them with separate cables.
Designed with a protective, 360-degree bumper case, and able to charge your iPhone with the push of a button. This protective battery case will add 15+ hours of talk time or nearly 10+ hours of web browsing time to your iPhone X's battery life. Unlike plenty of other battery cases, the Trianium Atomic Pro is actually quite slim and compact (though it's definitely not designed to be ultra-thin and minimalist).
This case not only will provide you with eight extra hours of talk time thanks to its 3,000mAh battery, but it also features a rubbery textured surface that allows you to grip your phone extra tight. The Maxboost iPhone X Battery Case is designed with a lightweight look and feel, and shouldn't add too much bulk to your iPhone X. Plus, an LED indicator will tell you when your case needs to be charged, If you need to turn it on or off in an instant. You can hit the button at your leisure!
The Alpatronix BXX battery case is great for those who love wireless charging. This case comes packed with 4200mAh of extra juice so that you can get a little more than a full charge from it throughout the day. If you already have a wireless charging pad at home, just place the phone with this case on, and both will charge like magic.
If you care about protecting your iPhone X as much as you care about keeping it charged up, the EasyACC Rugged Battery case wraps your iPhone in solid protection as well as a battery. With a 5,000mAh battery pack, you should be able to get just about twice as much time on your iPhone X before recharging. Plus, its rugged design will ensure that any minor drops or dings won't leave your iPhone X any worse for wear.
Who says a battery case has to look boring? Casely offers several colorful and fashionable battery cases from plaids and florals to animal prints for all you cool cats and kittens out there. Don't let the good looks fool you: this is a 4,000mAh case, enough to give your iPhone X a full recharge.
Why not the Apple Smart Battery Case?
While Apple does make a Smart Battery Case for the iPhone XS and that case will fit an iPhone X, it isn't a perfect fit. The Smart Battery Case for the iPhone XS is a slight mismatch for the iPhone X. While it does fit and charge your iPhone X, it also has the speaker and microphone holes in very slightly different places. Plus, the camera hump is just a bit off, making the Apple Smart Battery case a less than ideal choice.
Our top pick is the Mophie Juice Pack Air because Mophie has a great reputation of making fantastic accessories for the iPhone over the years. I've personally used charging pads, battery cases, car chargers, and other accessories from Mophie over the years, and the quality is always a standout.
If you're looking for something a little cheaper, the Maxboost iPhone X Battery Case is a solid choice. Offering more than its fair share of extra battery power and in a slimmer package than a lot of other battery cases, it's a good way to stay charged up without breaking the bank.
One thing for sure is that whichever case you choose to from the list above, you will extend your iPhone X battery life by a mile and find yourself charging your iPhone a lot less.
Want an alternative to the Apple Watch Classic Buckle? Check these out.
While the Apple Watch Classic Buckle Band is beautiful to look at and a truly timeless accessory that matches almost any outfit and occasion, the price can seem a little steep for some.
Protect your iPhone 8 with a case that's great!
If you're looking for some great iPhone 8 cases, there are plenty of options — especially since a lot of them were made for the iPhone SE.
